289 M 1975 Peterbilt battery cable problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by turnerbros, Mar 29, 2025.
  1. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    289A would be an aluminum frame. M, well I was researching to see if M stood for metal, and look what I found! 1975 PETERBILT 289M For Sale in Stockton, California
    Thats a steel frame, not an aluminum frame.
  3. wore out
    wore out Numbered Classic
    17,344
    215,394
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I was thinking A was aluminum. M was aluminum with metal or steel cross members and S was steel
  4. AModelCat
    164,847
    How well did aluminum frames stand up? Never seen one in real life, didn't even know they existed until a couple years ago.
    Oxbow and wore out Thank this.
  5. Big Road Skateboard
    7,115
    40,386
    May 2, 2021
    All the ones I saw working were farmer owned here in Arkansas. All looked good. I saw an old W900 in NW Nebraska last year I posted a pic of. It was also aluminum, and clean.
    @Oxbow posted pics of his trucks frame a while back. It resembled some nasty battery terminal corrosion.
    Oxbow, wore out and AModelCat Thank this.
  6. Big Road Skateboard
    7,115
    40,386
    May 2, 2021
    Not bad priced. A guy could build a nice truck outta that. Should go quick
    Bean Jr. and Oxbow Thank this.
  7. Oxbow
    Oxbow Road Train Member
    13,672
    141,782
    Nov 24, 2015
    Mine would have probably held up much better, but it used to be owned by a crane company in Nevada and I imagine that the mag chloride they put on the mine roads got in between the steel liner and the aluminum frame and caused a chemical reaction similar to rust jacking. Our state uses salt brine or some sort mag or calcium chloride on the roads in the winter now and that didn't help the situation.
  8. Big Road Skateboard
    7,115
    40,386
    May 2, 2021
    IIRC, the pic you posted looked like 3 or 4 inches of rust jacking. May be why I never realized it was aluminum. Could be I'm just blind and inattentive too.
    I didn't see those 6 fingers on that gal either. Hell, I didn't notice she had hands till it was pointed out
    wore out and Oxbow Thank this.
  9. AModelCat
    164,847
    I've got a pic of the original frame on the W9. Same deal, rust jacked so bad the web of the outer rail resembled a buttoned headliner in places where the bolts hadn't snapped. The rust jacking was bad enough it actually cracked some of the suspension brackets.
  10. turnerbros
    turnerbros Bobtail Member
    10
    11
    Mar 29, 2025
    Yup thats my Truck soon to be someone else's. Unfortunately the rep put a Cat engine instead of Cummins engine. Also I have 379 1990 Peterbilt also for sale it runs well take look. It was also my fathers. Needs tires though. 1990 PETERBILT 379 For Sale in Stockton, California
    Bean Jr. and Big Road Skateboard Thank this.
  11. Big Road Skateboard
    7,115
    40,386
    May 2, 2021
    Pretty clean California trucks. I imagine you won't have them long. I may holler at you about that 379.
    How soon do you need to move these from where they are?
