290wb vs 300 wb 389
Discussion in 'Ask An Owner Operator' started by Blkcowboy, Oct 29, 2018.
  1. Blkcowboy
    Blkcowboy Light Load Member
    282
    85
    Apr 11, 2018
    is there a big difference in the ride undecided between the 2
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    If the suspension is the same you won't notice any difference.
    Oxbow and Blkcowboy Thank this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    The 290 will probably turn a little nicer in tight spots, be about the only difference I think.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    You'll need a football field to turn either one of those around! lol
    adayrider, Nothereoften and Blkcowboy Thank this.
  6. Blkcowboy
    282
    85
    Apr 11, 2018
    Lol I like the look of the longer wb
    KB3MMX and Bakerman Thank this.
  7. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I have a 242" wb and some of the places I go to in LA are tight.
    Wouldn't even think about any longer wb.
    stwik, Derailed, ramblingman and 3 others Thank this.
  8. pavrom
    pavrom Road Train Member
    3,217
    7,419
    Apr 29, 2012
    NE illinois
    To be honest I have 2009 kw t660 and 1999 kw w900 , w900 rides so much better ...sorry it's bit off topic ...footba fo field required as someone mentioned :)
  9. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    The 300" wb truck will be around 600 pounds heavier as it will have a frame insert in it. Peterbilt put that in when ever the wb gets over 290" on newer tractors.
    Cat sdp, KB3MMX, Oxbow and 1 other person Thank this.
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Gotta know what you're going to do with it first, see if you'll be able to go much longer and not run #### over.
    KB3MMX, Bakerman and Blkcowboy Thank this.
  11. REO6205
    13,168
    60,500
    Feb 15, 2014
    California.
    Just be sure to back off the steering stops as far as you can without rubbing a steer tire on anything.
    Nothereoften, Oxbow and Blkcowboy Thank this.
