3.70 vs 3.90, what is the difference?
Discussion in 'Ask An Owner Operator' started by Thotphobia, Aug 23, 2021.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Okay guys, help me solve this once and for all, which gear ratio is better, 3.70s or 3.90s? We’re really looking into one of these. If two semis were put side by side, one with 3.70s and other with 3.90s, same HP same Torque, which would be faster ? Would it be a huge difference? Please help. We’re looking for a semi, but there’s sooo many with 3.90s and rarely any 3.70s
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    That's really a loaded question.
    You're talking about two identical trucks what is the horsepower/ torque? Where are you traveling? Are you deep in the mountains or you completely on flat land? Are you pulling legal loads or are you pulling a hundred and fifty thousand pounds?
    The short answer is that the 390s will give you a lower gear for pulling out, it will give you better pulling power on the Hills, but the 370s will give you a faster top speed and a lower RPM at whatever speed you Cruise.
    Honestly it's best to look at whatever engine is in it and find out what the optimum RPM for cruising is and then pick your rears for whatever speed you're going to cruise.
    That will give you the best fuel mileage and driveability.
    Rideandrepair and John E. Thank this.
  4. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    Don't forget tire size mathers unless both trucks have the same size tires
  5. Cat sdp
    Cat sdp . .
    21,311
    76,259
    Apr 8, 2012
    Orion's Belt
    The difference is almost nill. If the tires and transmission are the same……
    If your gonna run all highway the 3.70 would be slightly better shorter heavier the 3.90 would be better….
    petefan4000, Rideandrepair and John E. Thank this.
  6. AModelCat
    164,835
    Top speed would be faster with 3.70.
    Top of the hill? They'd be pretty much even. Pulling power comes from the engine.
    Brettj3876 Thanks this.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Top speed will only be about 5 mph different.
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    They will both pull a hill at exactly the same speed. Even a truck with 4.11s and truck with 3.55s everything else being the same will pull a hill the same speed. The truck with 3.55 will be 1/2 or a full gear lower but pull it the same speed. The only advantage you have with the taller number rear is start off is easier
    D.Tibbitt, John E., blacklabel and 2 others Thank this.
  9. Cat sdp
    Cat sdp . .
    21,311
    76,259
    Apr 8, 2012
    Orion's Belt
    I smoked a lot of weed in high school but the physics on that statement don’t sound correct…….
  10. AModelCat
    164,835
    Simple. To put the same amount of torque to the ground with a 3.55 as a 3.90 you'd need to put the transmission in a lower gear. Speed is lost in the transmission but is made up for in the rear end.
    Rear end gearing isn't the magical solution to rocketing up a hill like everyone thinks.
  11. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    So did i but everything else the same they'll top the hill at the same speed. Schlumberger had 425 isx 12s. The newer ones were geared to run 1600 at 65 and the older ones ran 1900 at 65. Didn't matter what truck i was in they both would pull the same mph on a hill. The longer legged one was just a gear lower
