3 Starters in 10 Months???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Crossbones, Dec 18, 2021.
  1. Crossbones
    Crossbones Light Load Member
    115
    66
    Mar 10, 2018
    Western NC
    2014 ProStar, last 8 EN123846, Maxxforce N13, automatic. Key switch, relay, batteries, wiring are all fine. Getting power at starter but won't crank. Now here's the catch...this is an intermittent issue and it always starts and ends the same way. At first, turn the key a couple of times and it will start. Next time it may be 5 to 10 times and it will start, then 10 to 20, 20 to 50 and so on until it just doesn't work at all. Replace starter, get a month or so out of it and the entire process repeats. No mechanic I've been to has been able to diagnose this. I'm hoping one of you has seen or heard of this happening to someone else and can provide some help. Thank you in advance.
    jamespmack Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    You have wiring issue. You likely have voltage but no amperage and a bad connection/excessive resistance somewhere.
    You need someone with a good understanding of auto electrical theory and knows how to measure voltage drop to locate the issue.
  4. Crossbones
    115
    66
    Mar 10, 2018
    Western NC
    I have noticed that my volt meter fluctuates between 12 and 14+ pretty regularly. It's never really steady. Unfortunately, electrical issues are not something I know much about. Thank you for the reply.
  5. Ridgeline
    22,720
    123,330
    Bad ground.
    tscottme Thanks this.
  6. Crossbones
    115
    66
    Mar 10, 2018
    Western NC
    But why the steady decline? New starter works fine for about a month then the whole process begins again. Each starter I've pulled out is fried.
  7. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    I have little experience dealing with electrical issues. I have to say, though, it reminds me of my problem 10 years ago. The solenoid on the firewall was apparently my problem. I was told undercurrent can cause those to fail. I replaced it again, but I cleaned the firewall bare to get good contact. I never had a problem starting the truck again for the remaining 4 years I owned it. I suppose I could have bought and installed a defective solenoid the first time I replaced it a few months before the 2nd one.
  8. Crossbones
    115
    66
    Mar 10, 2018
    Western NC
    If everything I've learned during this nightmare is correct, this model does not have the slave solonoid on the firewall. (2014) Everything I had seen pointed to that as the culprit, only to find my suspect had a watertight alibi: it was never there.
    slim shady Thanks this.
  9. MRMTRANS
    407
    440
    Apr 28, 2015
    Undercurrent to the starter solenoid? Bad grounding?
  10. Crossbones
    115
    66
    Mar 10, 2018
    Western NC
    Pointing towards alternator/voltage regulator?
  11. Crossbones
    115
    66
    Mar 10, 2018
    Western NC
    This to me looks like a missing ground opportunity maybe?
