30/30 Brake chamber
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by istumped, Sep 2, 2024.
  1. istumped
    istumped Medium Load Member
    504
    241
    Feb 8, 2015
    First off this is for an AG application. Does it matter which hole I use for a single line air system to operate this brake chamber? I have always delt with a 2 line system. Which inlet do I use?
  3. OldMainiac
    OldMainiac Light Load Member
    187
    1,887
    Aug 2, 2024
    The port toward the rod supplies air to release the brake, rear is to apply brakes. I'm not sure what your application is but I don't believe this is going to do what you want. You need a regular pancake style like on a steering axle.
    Bean Jr. and lester Thank this.
  4. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    I think you got that backwards. the front port(the one closest to the push rod applies brakes. the rear port releases the park brake. but yeah not sure how that will work in your application unless you cage the park side
  5. istumped
    504
    241
    Feb 8, 2015
    What's that crossover line on top do? Never seen a 30/30 have that?
    BoxCarKidd Thanks this.
  6. OldMainiac
    187
    1,887
    Aug 2, 2024
    I've never seen one either but, it's not a high pressure type connection. :dontknow:
  7. OldMainiac
    187
    1,887
    Aug 2, 2024
    Your right @lester , posting past my bedtime is bad. ;)
    Oxbow, Bean Jr. and lester Thank this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    I see no drain holes. I would say the tube is to keep pressure equal or vent?
    Oxbow, beastr123 and AModelCat Thank this.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    Used to expel air from the back of the diaphragm. Kind of bounces it back and forth. If you look there are no other vent holes. Great for mud runners, liquid nitrogen sprayers and such. Keeps all that junk out of the chambers.
    Sounds like he could use just a basic single service chamber but I am sure he has something worked out by now.
    Oxbow, Rideandrepair and beastr123 Thank this.
  10. istumped
    504
    241
    Feb 8, 2015
    I have thought about a regular service chamber. But which one will work properly. Also needs to have parking on chamber as well
  11. Goodysnap
    3,778
    9,212
    Jul 12, 2017
    Some older ag trailers and especially lowboy and tank trailers only used service chambers. The park brake was applied by air when the gladhand is disconnected. If the air bleeds off your park is gone. It was common to hook up the gladhand before connecting to charge the trailer before backing under.
    In order to install spring brakes you would have to replumb and different brake valves.
    Oxbow, BoxCarKidd and OldMainiac Thank this.
