3000w pure wave inverter
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Wespipes, Dec 31, 2019.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    I just got my inverter in the mail. I went with the aims 3000w pure wave. And omg this thing is massive! I'm a bit nervous to install this thing in my truck. I got the install kit with it, which recommended the 1/0 awg gauge wires. They're bigger then my trucks battery cable wires. Anyone run a 3000w pure wave inverter in their truck? What cable sizes did you use? I'm nervous about my truck burning down lol
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    I run a 7000 peak 3,500 continuous one in my service truck.
    Ran 0/0 wiring all the way.
    Wespipes Thanks this.
  4. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
    The two main things are the fuse and terminal ends.
    You want the fuse as close to the battery as possible.
    The terminal ends need to be tight on the cable or you can have heat build up there.
    Mike250rs and Wespipes Thank this.
  5. Wespipes
    1,037
    1,816
    Jul 14, 2019
    Phew. That makes me feel a lot better! Mine 3k continuous 6k peak. Did you run a fuse between your battery and your inverter? Mine came with a 300 fuse.
  6. Wespipes
    1,037
    1,816
    Jul 14, 2019
    You answered my second question about the fuse! Thank you
  7. Wespipes
    1,037
    1,816
    Jul 14, 2019
    I am having this professionally installed. Getting an apu put on the truck Thursday. He said hed install it no charge.
    Mike250rs and Cabinover101 Thank this.
  8. Mike250rs
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    It should have a remote switch included. In not you can also put a battery disconnect switch that will cut power completely to the inverter while not in use
    Wespipes and Cabinover101 Thank this.
  9. Wespipes
    1,037
    1,816
    Jul 14, 2019
    Yes it came with a remote switch and 30' of cable for that. I do want to eventually get a battery disconnect terminal. I'm sure those cant be expensive
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    They only draw as much power as the load you place on it.
    If you never put any more than 1500 to 2000 watt loads on it you'll be good.
    laaylor and Wespipes Thank this.
  11. Espressolane
    18,756
    117,702
    Currently have that same inverter in this truck.
    No problems. Fuse at battery terminal, 0/0 wire. Also soldered the terminal ends, then used heavy shrink tube on them. Make sure to put grommets any where the wire passes through holes. Use good ones. Keep the run as short as possible.
