300lbs over on trailer
Discussion in 'Experienced Truckers' Advice' started by TigerShark, Nov 18, 2016.
  1. TigerShark
    TigerShark Medium Load Member
    454
    329
    Nov 5, 2015
    300 lbs over on trailer, no way to fix load weight. I'm going west through the Muldrow Ok scale think they will pop me?
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    That's less than 1% over gross on a set of tandems. I highly doubt their scales are even that accurate. Run it, you'll be fine.
    Rubberduckin, RERM and TigerShark Thank this.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I can't answer that but if it were me I'd go with it.Three hundred lbs over is nothing.I've been 500 over many times during my career because I was too lazy to move the tandems and never did I get a ticket or asked to get it legal by the DOT.
    Rubberduckin and TigerShark Thank this.
  5. TigerShark
    454
    329
    Nov 5, 2015
    I'm only sitting @ 79300 I'm just going to kick myself if they nail me and it takes 30 minutes that I could have gone around
    Rubberduckin Thanks this.
  6. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    What's the weight on all three axles?
  7. alpo718
    alpo718 Light Load Member
    54
    43
    Apr 20, 2015
    You should be good. OK usually isn't too bad, but I run dry bulk, so we can't move things around as easy and they know it.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Tolerance is 1000 pounds .. but... some scales yeesh..
    The problem is this for me... the preweights sensor that you trip coming off the interstate decides if you go onto the platform for a really good look at your weight. It will do it at 79000 and up. Once or twice Ive put a outside tire or several outsides slightly off the preweights itself.
  9. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Just jam on the brakes a few times. ;)
  10. wore out
    wore out Numbered Classic
    17,375
    215,833
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Most of the time that coop is closed. You can get off at exit 12 I think it's Atkins then 64 west to 540 south. Then 255 truck route. Brings you. Back out to 64 by the old stockyards, right back to 40.
    TigerShark, MJ1657 and 7-UP Thank this.
  11. TurnpikeTourist
    TurnpikeTourist Bobtail Member
    43
    65
    Apr 12, 2015
    Long Island, NY
    I could be wrong, and please correct me if I am, but isn't there a 400lb exemption if you have an APU? Obviously not for the trailer axle weight, but if your over on your drives that could save some worry.
