320lbs overweight on drives, run it?
Discussion in 'Experienced Truckers' Advice' started by Moneyhungrytrucker, Jun 27, 2020.
  1. Moneyhungrytrucker
    Moneyhungrytrucker Light Load Member
    218
    261
    Apr 21, 2017
    320lbs overweight on drives, run it? I already slide the tandems as far forward towards the tractor as they will go.
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    158,090
    if u got an apu ur already legal... thats about 40 gallons of fuel, regardless.
    bryan21384 and PE_T Thank this.
  4. WHY NOT
    WHY NOT Light Load Member
    160
    117
    Oct 18, 2015
    pretty sure it would have to be more than that to get a ticket anyways. Then again i haul bulk and rarely axle out just right so im pretty used to it, I just tend to avoid certain places.
    PE_T Thanks this.
  5. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,967
    Nov 1, 2017
    The Sticks, Idaho
    Where are you? Most places I would run with it. Or, if you know how, you can use a 4" strap to slide the rear most skid back to the doors and use a load lock to keep it from sliding back forward. Takes about 15 mins if you know what your doing.
    Accidental Trucker, rachi and PE_T Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,464
    6,390
    Nov 16, 2013
    Baltimore, Maryland
    Run it. You burn the fuel and you will be legal. Fuel is a little over 7lbs a gallon. Depending on outside temperature as much as 7.5. Always round up to 8lbs per gallon to be safe. I doubt DOT would write you for 320 over
    PE_T and MACK E-6 Thank this.
  7. MACK E-6
    50,252
    240,652
    Run it. That’s not worth sweating.
    Worry about that when it’s more than 1000 lbs.
    Cattleman84 and PE_T Thank this.
  8. Moneyhungrytrucker
    218
    261
    Apr 21, 2017
    I am in Indiana, I should have scaled it near the shipper, but I knew I was well under 80,000 gross, I didn't think it would be a problem. Got 400 miles down the road and scaled it only to find out its 320lbs overweight on drives, and cant slide the tandems forward towards the tractor anymore. I normally always scale, this time I got lazy, I made a mistake, next time I am scaling near the shipper.
  9. Cattleman84
    10,057
    71,967
    Nov 1, 2017
    The Sticks, Idaho
    Just run it... Had you done the same thing but were over 1K then you could you a stap to slide a skid or 2 back to the doors and thus would solve the problem... While leaving the tandems allbthebway forward
  10. Moneyhungrytrucker
    218
    261
    Apr 21, 2017
    I pretty much did run it most of the way already .... LOL .... I guess I am just worried about hitting a weight station now.
  11. Moneyhungrytrucker
    218
    261
    Apr 21, 2017
    No APU
