33 HP 2 issues
Discussion in 'CB Radio Forum' started by _33, Jan 14, 2019.
  1. _33
    _33 Light Load Member
    82
    22
    Dec 6, 2018
    Atlanta, Ga
    I have a Galaxy 33hp 2. In the morning when I first get in my truck I have the RF gain wide open, my squelch date wide open and yet there is zero static and no Voice receive. When I key it up I get a high SWR tone. As the morning progresses the static comes in, the SWR tone goes away and my receive improves. Any thoughts?
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
  4. _33
    82
    22
    Dec 6, 2018
    Atlanta, Ga
    Pretty cold. Around 34-36 degrees
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Could just need time to warm up...or a cold solder joint somewhere.
    rabbiporkchop Thanks this.
  6. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    Engage the choke and let it run on high idle while you fill your coffee thermos before scraping ice off the windshield.
    (I don’t really miss those days, but the New Yorker with its optional gearing and police-spec V8 440 was great to listen to as it woke up. Subtle changes. And —time to leave — slip the cassette into the AM/FM/FM-Stereo player to let The Presidents Own play, “Anchors Aweigh” as you cast off the mooring lines and rang the engine room to bring in the TorqueFlite).
    If this is what’s needed , think of it as part of performance.
  7. _33
    82
    22
    Dec 6, 2018
    Atlanta, Ga
    Also, as I speed up my static gets worse. If I run a direct hot and ground to the battery do you think that would help? I think I am getting a lot of engine noise.
  8. Ridgeline
    22,726
    123,456
    Please start with your antenna, get it checked by someone who knows what they are doing with an antenna analyzer. then go from there.
  9. _33
    82
    22
    Dec 6, 2018
    Atlanta, Ga
    Thank you for the help and advice.
  10. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    If you have a spare radio swap it out see what the changes are, Sounds like a cold solder or maybe some caps going away. I'd probably try refloating the board, or fire it up bench with a can of freeze spray in one hand and a heat gun in the other, also pressure on the board can show a bad soler.
  11. _33
    82
    22
    Dec 6, 2018
    Atlanta, Ga
    And what do you mean by pressure on the board can show a bad solder? I'm learning but some of these responses are still a little over my head.
