3406 b model engine flooding with fuel
Discussion in 'Peterbilt Forum' started by mrc_83, Nov 10, 2021.
  1. mrc_83
    mrc_83 Bobtail Member
    Wassup everyone. I have a 379 Pete 1993 with a 3406b model and my engine is flooding with diesel. Took it to the shop and had one bad injector so I changed them all. Supposedly that was the problem but it’s still filling up. Anyone had this problem before or have any advice?
  3. Big Road Skateboard
    7,250
    41,325
    May 2, 2021
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    please explain flooding with fuel. Cylinder filling with fuel ,slobbering fuel at exhaust manifold,Cylinder hydrolocking with engine off???
    shooter19802003 and Bean Jr. Thank this.
  5. Oxbow
    Oxbow Road Train Member
    13,704
    142,242
    Nov 24, 2015
    The 90 degree fitting coming off of the back of the injection pump, and where the return fuel line connects, has a tiny orifice in it. This can get plugged and cause fuel pressure to go way up. I am not sure what happens if this is plugged, or what you mean by flooding with fuel, but it doesn't cost anything to check.
    Roger McG, shooter19802003 and cke Thank this.
  6. Oxbow
    13,704
    142,242
    Nov 24, 2015
    Is fuel getting into the oil?
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Restricted pump return will blow the side plate gasket out, a plunger would need to fail before the fuel could make it through the pump to the crankcase.
    Its likely a line under the rocker covers is leaking if the nozzles were replaced.
    AModelCat and Oxbow Thank this.
