3406 fan won't come on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rick Wilmath, Aug 27, 2016.
  1. Rick Wilmath
    Rick Wilmath Light Load Member
    57
    May 15, 2016
    I have a 1993 Freightliner and a 3406 motor. The engine fan won't come
    on either automatically or manually.
    I checked the manual switch and it is getting juice to the switch
    and when I turn the switch on voltage is going out the other side.
    When I turn the manual switch on I heard an air noise at the engine
    and found it at the solenoid. There is a small hole in the solenoid
    and air is coming out.
    Does the solenoid send air to the fan hub?
    Is there a way to check to see if the air is getting to the fan hub.
    The fan itself freely spins. I don't hear any bearing noises.
    Thanks
  3. AModelCat
    165,214
    Most fans use air to hold the fan released and exhaust it to engage it.
    Rick Wilmath Thanks this.
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Disconnect the air line to the fan & see if air is getting to the fan
  5. Rick Wilmath
    57
    May 15, 2016
    So if air is being exhausted out the solenoid does that automatically mean that the fan clutch isn't working?
    Thanks
  6. kwswan
    kwswan Road Train Member
    2,049
    11,277
    Jul 26, 2009
    mcminnville,tn.
    No,it means the solenoid could be bad.
  7. 062
    062 Road Train Member
    6,350
    34,015
    Oct 20, 2013
    Depends on which fab hub you have. Some lock up air on,others air off.
    Easiest way to find out,remove line from solnoid going to hub. Any air coming out? If not the safest way is jump 12v to solnoid,but you can start the motor just make sure nothing can get in fan. If still no air solnoid is bad.
  8. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    You can also take the line loose going to fan and use blowgun to engage and disengage fan to rule the fan out leaving the solenoid. If you are on the road and need to get back home to fix you can lock the fan to the hub with two bolts I believe 5/16 maybe 3/8 I don't remember right off. you will have to locate holes and line up.
  9. Rick Wilmath
    57
    May 15, 2016
    Thanks everybody for the help. I'll try the ideas and let you know.
  10. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    either got a bad solenoid or bad fan clutch if the wirings and switch is still good
