3406 high coolant temps
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rank, May 4, 2018.
  1. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    4 yrs later and I’m still chasing this high coolant temp problem on my 86 359. It’s worse this year than last so I spoke to an old school mechanic I saw at lunch today. since I’ve already changed rad, t-stat and water pump I asked the old fella if he thought the coolant passages might be plugged. He said no and suggested firing rings. He said 3406 was famous for it. Told me to pull off the fan belt and check the coolant reservoir for bubbles.
    Comments?
    BigBob410 and Oxbow Thank this.
  3. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    @rank there’s a kit you can buy, you put the end of the overflow hose in it, and it’s supposed to change colors if combustion gasses are present. I’ve never used one myself, but it may be something to look into if you’re concerned about that.
    When mine starts running warm, it’s always dirt and crud plugging up the fins on the radiator. A little time with an air hose and she’s good to go again.
    KB3MMX, SAR, rank and 2 others Thank this.
  4. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Firing rings are basically head gasket issues iirc. Are you having other symptoms that point to a head gasket problem? How hot is hot?
    KB3MMX and rank Thank this.
  5. wore out
    wore out Numbered Classic
    17,535
    219,045
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Take a bottle of water and run your over flow hose into it. With it warned up good and rev the engine to about 1500 see if it bubbles. If not rig up an extension on the hose and tie it to mirror or hold it what ever suits you and go for a drive loaded don't be easy make it run full boost. You didn't say it was loosing coolant so I wouldn't think you have issues there.
    That bleed hose from front of head to top radiator tank if it's restricted it will get warm and mirror a head gasket or liner issue sometimes.
    Oil cooler passages are notorious for stopping up and restricting flow.
    Thermostat housings will erode internally and cause issues but you woulda seen that already.
    Also check just to be sure the fan is pulling air from outside the radiator. With hood up RPM at 1000 fan engaged throw a dry wash cloth up toward the radiator front. It should pull it and hold it there. I have seen more than one backwards fan blade.
    When you done the pump did you notice if it had a metal or plastic impeller. New backing plate?
    SAR, Oxbow, BoxCarKidd and 4 others Thank this.
  6. rank
    9,919
    113,510
    Feb 11, 2010
    No. No significant oil seepage around the bottom of the head. It can make ~26 psi boost if I ask it to.
    I turn the fan on at 205 but I'm sure the sky is the limit if I didn't turn the fan on. Couple of days ago it was ~75 degrees and I was 82,000 gross. Pulling even a small hill I had to run the fan. Just running down the road at 60 mph was 190-195.
    KB3MMX and BigBob410 Thank this.
  7. special-k
    1,523
    3,258
    Dec 27, 2008
    Kind of a dumb question but have you verified the guage is accurate? Hows the oil temp? It should be somewhat close
    rank Thanks this.
  8. 062
    062 Road Train Member
    6,352
    34,034
    Oct 20, 2013
    What's your pyro reading when it heats up?
    rank Thanks this.
  9. rank
    9,919
    113,510
    Feb 11, 2010
    Gauge was bang on 212 when I measured boiling water. Oil temp. ~150 15w40 Delhi 400 on a 75 deg day
  10. rank
    9,919
    113,510
    Feb 11, 2010
    Pyro temps also skyrocket they and the coolant gauge climb together. I start dropping gears on a pull at 900 deg
    wore out Thanks this.
  11. wore out
    17,535
    219,045
    Jun 5, 2013
    That makes it sound like a boost leak or lack of air problem
    KB3MMX, SAR, Oxbow and 2 others Thank this.
