Anyone knows how to remove the reservoir thats on top of the pump. It has a wing nut but only removes the top of the reservoir. Any clues? I have a leak between the reservoir and pump.
3406 power steering pump reservoir
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 377pete, Jun 30, 2017.
Look between the pump and reservoir with a flashlight. It is likely it spins on a pipe fitting. If so just use a quality filter wrench.
AModelCat Thanks this. -
Another possibility is at the very bottom inside the reservoir is a bolt or two.
After you drain all the oil out you may see the nut at bottom inside the tank on the inlet tube
bigguns and spyder7723 Thank this.
