3406b 4MG jake brake question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by parkway, Mar 11, 2026.
  1. parkway
    parkway Bobtail Member
    11
    12
    Jan 16, 2024
    I just finished putting a new head on my 3406b 4mg. The truck is running well but jakes not working. There is power to the terminal at the head and they are connected inside the covers. I had a helper in the shop while reassembling. I think the jake heads may have gotten switched front for back. I would like to run the truck until I have a chance to get it back to the shop for further investigation, switching jake head position, whatever. Is there a risk of damaging the valve train if they are switched and I continue to run the truck?
  3. Sons Hero
    Sons Hero Road Train Member
    3,051
    31,298
    Jan 8, 2021
    Indiana
    Paging @woreout
    Speedy356 Thanks this.
  4. Speedy356
    Speedy356 Medium Load Member
    533
    3,322
    Oct 13, 2021
    I think you meant @wore out :D
    Sons Hero Thanks this.
  5. Sons Hero
    3,051
    31,298
    Jan 8, 2021
    Indiana
    yep my bad
  6. wore out
    wore out Numbered Classic
    17,331
    215,233
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Yes they are backwards. Won’t hurt nothing but don’t use them just to be safe.
    mile marker 27 and W923 Thank this.
  7. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    Possibly the little o ring on the connector pipe is missing….Ive seen that cause them not to work either….still going to have to take things apart to find out
    mile marker 27 Thanks this.
  8. parkway
    11
    12
    Jan 16, 2024
    Thanks for the reassurance wore out. I ran it yesterday with perace of mind after seeing your (therapeutic) message. (much appreciated) And yes W923, I'll double check those new orings on the oil connecter pins. We may have clipped them when reassembling.
  9. parkway
    11
    12
    Jan 16, 2024
    Ok, so they were flipped front top back. Now I want to adjust them for optimal performance. It is a 4mg55041. should I set the jake contacts at .070 or .080?
  10. wore out
    17,331
    215,233
    Jun 5, 2013
  11. parkway
    11
    12
    Jan 16, 2024
    Thanks again wore out. Now I can finish this operation. But first I'll have to plow about a foot of snow out of the driveway. Last week I thought it was springtime!
    W923 and wore out Thank this.
