3406b issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by nate1206, Jun 20, 2025.
  1. nate1206
    nate1206 Bobtail Member
    7
    12
    Jan 8, 2023
    Trucks a 90 peterbilt 379. 3406b in it. The engine just dies. This issue seems to only happen when it's at operating temp. And only seems to happen so far when I'm coming to a stop and clutch it or at times when I rev it and let off suddenly. Never under load. I can usually save it and keep it running if I catch it in time and give it fuel but if I dont it just dies. It doesn't happen at every stop. It doesn't happen every time I let off but it happens enough to be a pain in the rear. Any help would be appreciated
  3. wore out
    wore out Numbered Classic
    17,432
    216,985
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    What’s your low idle RPM?
    most likely it’s gonna be a dash pot issue
    cke and Big Road Skateboard Thank this.
  4. nate1206
    7
    12
    Jan 8, 2023
    Right around 650 according to gage
    wore out Thanks this.
  5. wore out
    17,432
    216,985
    Jun 5, 2013
    That’s pretty close you can bump it to 7.
    Look at the very back of the pump. You gonna see a 7/16 nut with like a flat head set screw in it. Crack the nut turn the set screw out 1/2 turn
    that’s gonna give the dash pot a little more oil and hopefully fix your issue if not you probably need to have the governor section worked on
    cke, BoxCarKidd, Stay Puft and 2 others Thank this.
  6. nate1206
    7
    12
    Jan 8, 2023
    I'll give that a try and see how it goes. It's closer to 6 by the looks of it
  7. nate1206
    7
    12
    Jan 8, 2023
    That seems to have worked. Drove it around for 40 minutes and couldn't get it to replicate like I could before. Gonna unhook and do it again tomorrow and see if it does it but thank you for the help and quick replies
  8. nate1206
    7
    12
    Jan 8, 2023
    Took it out today for a few hours and that seemed to work. It wouldn't replicate what it was doing the other day at all no matter how hard I tried. So I believe it's good to go. Thank you for the help
