3406b low boost and fuel pressure issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rs72z, May 28, 2022.
  1. rs72z
    rs72z Bobtail Member
    34
    39
    Oct 7, 2021
    95 kw 3406b
    engine has a mississippi red hot turbo, , i believe is what its called, also has ceramic exhaust manifold, was making 32 lbs of boost. Suddenly dropped down to 20. Put a fueI pressure guage on it, 40 at idle drops to 30 under boost with load and will drop down to 20 and stay a few seconds and then go back to 30. I will give a list of what all i have done to it.
    cat filters
    afrc diagprham
    primer head,
    all lines suction and return, I did find some chunks of rubber stuck in the tee for the return.
    transfer pump
    cac and 3 boots, cac had mutiple small leaks
    none of this made any difference
    I finally found 4 of the 6 intake gaskets pushed out, thought this would solve my issue. It did pickup 5 pounds of boost to 25 lbs.
    When i go to Colorado it will make 27 lbs.
    Tanks pull down even also.
    also pyro never gets over 750
    Anyone have any Ideas.
    I have thought about fuel shutoff solenoid, but havent tried taking it off.
    Thanks for any help!
    Another Canadian driver and cke Thank this.
  3. AModelCat
    165,167
    Dunno what fuel pressure's supposed to be but if it can't get fuel, it won't make boost.
  4. rs72z
    34
    39
    Oct 7, 2021
    I have been told no lower than 30
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,560
    6,646
    Aug 26, 2014
  6. rs72z
    34
    39
    Oct 7, 2021
    Replaced it
  7. BoxCarKidd
    4,560
    6,646
    Aug 26, 2014
    Caught that on the second reading of your post. Maybe run a supply line from it into one of the fuel filer necks and drive it?
  8. rs72z
    34
    39
    Oct 7, 2021
    Never thought about that.
  9. Oxbow
    Oxbow Road Train Member
    13,695
    142,093
    Nov 24, 2015
    That's right where the fuel pressure runs on both of our B models. Without running a FAS type system, or custom building your own pump system like @wore out has don't think you're going to get much better. The 90 degree fitting to the return line on the back of the injection pump has a little tiny orifice in it that restricts flow and builds the pressure, but I can't see that getting bored out. If it gets plugged your pressure goes way up.
    I'll defer to @wore out as I'm not well enough versed in how they work to help.
  10. rs72z
    34
    39
    Oct 7, 2021
    I pulled the return fitting out and didnt see anything wrong with it, but I don't know what size the orfice is supposed to be.
    Im worried about the drops in pressure under boost when loaded.
