3406b low boost and fuel pressure issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rs72z, May 28, 2022.
  1. rs72z
    rs72z Bobtail Member
    34
    39
    Oct 7, 2021
    Please educate me some more.
    Talking with the mechanic at work, and mentioned what you said about the gasket between the ports on manifold under turbo being blown. He said that aftermarket gasket don't even have the gasket in the middle. Also this is a Full Tilt ceramic manifold if that makes any difference.
    I haven't had a chance to check any of the things you ask me to check yet hopefully this weekend.
    Thanks
  3. wore out
    wore out Numbered Classic
    17,455
    217,609
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Then he is using the wrong gaskets.
  4. rs72z
    34
    39
    Oct 7, 2021
    @wore out
    Check throttled opening this morning and it wasn’t moving breakover portion of lever at all. Adjusted it as far as I could and got it to move half way. It moved idlefrom 650 to 800 doing this, couldn’t get enough adjustment otherwise. I may have something wore out on the linkage.
    So what does breakover portion of throttle do?
  5. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    I would have changed the intake manifold temperature sensor.
    Like yesterday. To start with.
  6. wore out
    17,455
    217,609
    Jun 5, 2013
    Wouldn’t help it I assure you
    Another Canadian driver and Oxbow Thank this.
  7. wore out
    17,455
    217,609
    Jun 5, 2013
    Break over holds pressure on the govnor spring. There’s a fine line on adjustment you gotta take the 3/8 bolt out and move the lever 1 hole then adjust your linkage. After a few tries you’ll finally find something that will work
  8. Another Canadian driver
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    Sorry to hear that.
    Great engine, but fussy, sometime.
  9. rs72z
    34
    39
    Oct 7, 2021
    Does a mechanical cat have intake air temp sensor? If so why and what purpose? Just trying to learn?
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    No
  11. rs72z
    34
    39
    Oct 7, 2021
    I couldn’t imagine why it would.
