3406b low boost and fuel pressure issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rs72z, May 28, 2022.
  1. rs72z
    rs72z Bobtail Member
    34
    39
    Oct 7, 2021
    Yea had it hooked to positive and made sure it was working by touching a ground.
    The seal around the throttle shaft is leaking so it needs to come off anyway.
    Thanks again.
    Oxbow Thanks this.
  3. rs72z
    34
    39
    Oct 7, 2021
    Anyway for the throttle linkage to slip inside the rear housing? As in it's not moving far enough for full rack travel?
    wore out Thanks this.
  4. wore out
    wore out Numbered Classic
    17,488
    218,260
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Usually that’s the govnor spring guide but it causes an idle down slow condition. You could have linkage/bushing issues though. I can’t remember if it’s been this way since you’ve had it or a new problem but if you bought it that way some Jack ### may have been in there muck in around and have it really messed up. Key on engine off tie throttle all way back. Pull the cover on front of fuel pump with 2 7/16 bolts. Has one identical to it on back side. Anyway you’ll see the rack when you pull cover. Take your finger and try to push it back some more. There is a plug right on top of it put your timing pin in there and it should lay right at the back of that groove you see in the rack. I’m terrible at explaining things but I can get a friend to get you some pics outta my service manual if you need them. Just might take some collaboration lol
    rs72z and spsauerland Thank this.
  5. rs72z
    34
    39
    Oct 7, 2021
    It started when boost went away. I checked throttle then and it wasn’t opening all the way so I adjusted the linkage going to pedal.
  6. rs72z
    34
    39
    Oct 7, 2021
    How low is low on idle?
  7. wore out
    17,488
    218,260
    Jun 5, 2013
    I do not like below 650 or over 700. I have seen several arrangements that spec was 600. But I don’t like the sound that low it has almost a no oil sound usually
    kranky1 and Oxbow Thank this.
  8. rs72z
    34
    39
    Oct 7, 2021
    Pulled front cover off pump so I could see rack. Is it supposed to move as the throttle moves? If so it doesn’t. I can move it by hand quite a ways.
  9. wore out
    17,488
    218,260
    Jun 5, 2013
    How hard is it to move? It should move by itself for the most part
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Only ones I ever saw that sounded right running that slow were some 1800 rate 425 arrangements that were around in the ‘80’s.
  11. rs72z
    34
    39
    Oct 7, 2021
    I could slide it with my fingers but not real easy
