3406b low boost and fuel pressure issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rs72z, May 28, 2022.
  1. wore out
    wore out Numbered Classic
    17,462
    217,743
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Go looking for why it’s not moving freely. I can’t be 100 percent but I’d bet my shorts you found your issue
    Oxbow Thanks this.
  3. rs72z
    rs72z Bobtail Member
    34
    39
    Oct 7, 2021
    What should make the rack move if it doesnt move with throttle lever? Just trying to figure out how all this works together.
    Oxbow Thanks this.
  4. wore out
    17,462
    217,743
    Jun 5, 2013
    Oil pressure has a role as well as spring pressure. The servo hooks on back of rack bar at the nail head. It moves the rack. The plunger scroll gears are driven by the rack bar. So it could be a sticking plunger, weak springs, bar sticking in bushings....etc. it’s time to reman the pump basically unless you can fix it yourself
    Oxbow Thanks this.
  5. rs72z
    34
    39
    Oct 7, 2021
    I took the governor housing off today to replace the throttle shaft seal, also had bought new governor spring and wavy and flat washers just in case.
    When i got it off i found the spring on the governor dash pot was messed up along with the tiny clip that holds it on the governor shaft. robbed the parts off a old pump and put it back together..
    This is the part numbers i used, not sure which screw i need to turn to get the idle back down now.
    I went and drove it bobtail and it seemed to run better, i will have a load on it tomorrow to see for sure.
    (For the gov. Install push collar, 2N-0828 wavy washer, 2P9556 flat washer, 2N-0828 wavy, another 2P9556 washer, and an 8M9141 purple stripe gov spring. While it’s apart, screw out low idle (or Jake screw, whichever is there) one turn to compensate for new settings so you don’t have to do it assembled.)
  6. rs72z
    34
    39
    Oct 7, 2021
    Well it still only builds 25lbs of boost but it does rev higher now.
  7. wore out
    17,462
    217,743
    Jun 5, 2013
    Remind us what your expectations of boost should be?
    I have seen B models that made 36 I have also seen one that would run off and hide from them making 27. Without rack setting, and timing verification it’s a slippery slope
  8. rs72z
    34
    39
    Oct 7, 2021
    32 is what it did make.
    When I had the housing off I noticed that the torque screw was screwed out farther than the fuel screw. Is that normal?
  9. wore out
    17,462
    217,743
    Jun 5, 2013
    Yes one is longer than the other though believe it or not I’m drawing a blank on which one. Just check to make sure you have .030 spring pressure. I can’t see those moving at any rate. And it takes a big leak to take 7 psi of boost I mean a huge leak so that leaves turbo, fuel, or timing. Surely if the timing had slipped that much you would know by sound, it would rattle its tail off. Though the hyd return advances like the 4MG and up use will go full advanced just about when the clip comes off. But again you should hear that almost no missing it.
    Another Canadian driver and Oxbow Thank this.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Something must have been messed with. As delivered my 2EK 425’s put up 22psi and the 3ZJ C’s we’re around 24psi if I remember right. All of them 2100 rate Brakesaver engines. I’m not a fan of mystery pumps. Alway got a little sick feeling getting one with the seals gone off it. Most people should just leave those ####ing screws alone.
  11. Hammer166
    7,617
    27,873
    Aug 18, 2007
    ~8600+' and loving it!
    I've seen 2 different Cats with windowed blocks from guys screwing with them. Back in the 55 era when a lot of trucks were spec'd gearbound, so they'd turn the screw for more rpm.
    To their credit, both motors were still running with the rod flopping around. Kinda cool to see, but a bit expensive.
