3406b low boost and fuel pressure issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rs72z, May 28, 2022.
  1. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    The last couple of blown up Cats I’ve seen were common rail engines. Drop a tip off an E or a C15 that’s fuelled up at the time the piston, liner and half the rod goes right out through the side of them. Makes a most impressive hole. I’ve seen one of each now that did it. It may be worth noting both of those engines had Cat ReMan injectors in them.
  3. wore out
    wore out Numbered Classic
    17,546
    219,261
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I’ve seen lots of holes in pistons from to much thread exposed on fuel screws, cracked pistons from timing/wrong nozzles. Windowed blocks from overspeed and yes it’s cool as hell that they still run. Bent cranks from dropped valves and countless exducer wheels chewed up from spitting out a booger. But I guess my all time favorite was watching one blow a turbo in dodge city one night on the west end of the loop toward ingalls. Flames were cool as fook coming out of that Freightliner.....several big waves of them. Bout time I stopped ol boy was high tailing it outta there bout to trip on his beard. She got a snoot full of that oil and was running off. I’d thought it blowed 10 times but finally pulled down and seized. She was hummin for sure
  4. kranky1
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    Aluminum piston engines can put out an impressive shower of sparks and flames when they melt one down. I saw that a couple times in BC, lit the whole side of the mountain up like a big flash bulb going off.
  5. rs72z
    rs72z Bobtail Member
    34
    39
    Oct 7, 2021
    It has a bigger turbo on it and ceramic manifold. Thats all i know of.
    When i had the housing off the govenor i didn't measure the screw but just a guess the inner screw, torque i believe look to have about a 1/4" of thread left showing and the outer looked to be about 1/2". Again thats just a guess. I will have it back off again when cat gets me the correct throttle shaft seal.
    Oxbow and Another Canadian driver Thank this.
