3406b water leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bad habitz, Feb 26, 2025.
  1. Bad habitz
    Bad habitz Bobtail Member
    i bought an older flc sat for a few years. has a b model in it went to full it with water, and noticed coolant was leaking out of the dipstick. it filled the pan up with coolant. i pulled the pan and it looks to me as if the leak is coming from the back of the camshaft. whenever it starts leaking it pours down every side of the block all at about the same time. is there anything else that could be causing this besides a cracked block. im thinking it may have froze at some point
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
  4. wore out
    wore out Numbered Classic
    17,326
    215,175
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Pull the valve covers there are freeze plugs on top of head under the rocker shafts
    062 and Oxbow Thank this.
