3406C mech fuel issue?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FreightyAK, Sep 2, 2023.
  1. FreightyAK
    FreightyAK Light Load Member
    51
    42
    Aug 7, 2018
    AK
    So I have an 8pn mech C that yesterday while I had the truck idling cold it started sputtering chugging with white smoke and died. It wouldn't Start again. First thing I thought was fuel naturally so I primed it and it started right up and idled smoothly for a few seconds like nothing was wrong. No sputtering or smoke. Then suddenly it did the same and died. I can prime it and it will start and idle no problem for a few seconds then died with sputter and white smoke. I have no reason to believe it's the hoses from the tank as this was a sudden problem with no symptoms or warning. Both filters are full. I have not yet checked fuel pressure as I am working on getting a fitting to do so. Is it possible the transfer pump went bad just like that? What else could be preventing fuel pressure from building? Any other ideas?
  3. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    If you get it started, will it stay running on a high idle?
    If so, it is suction side, fuel restriction gauge hose (if you have it) is a likely culprit which is difficult to track down
  4. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    No. It sputtering and dies regardless of throttle input. The filters remain full
  5. skallagrime
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Return fuel flow check valve?
  6. Oxbow
    Oxbow Road Train Member
    13,665
    141,668
    Nov 24, 2015
    Mechanical pump. I believe the 90 degree fitting with the little orifice in it coming off of the injection pump is the only restriction on the return side.
    skallagrime and Stay Puft Thank this.
  7. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    I haven't had a chance to do much diagnosing yet, Ive been on the road. After talking to some folks I'm leaning towards obstruction in a line or fitting. When I unscrewed the separator there was 2 pieces of what looked like silicone on top of the filter. One was surprisingly large. I think that's what I will find pre separator. Just a hunch
    Crude Truckin' and Oxbow Thank this.
  8. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    So, ive pulled all the lines from the tanks, including the tee, to the transfer pump. Nothing is plugged up or restricted. I blew out the hoses and nothing came out. I removed the primary filter base and checked that too. All good. The line from the primary to the pump was mostly full of fuel but not all the way. Both filters were partially full. I got rained out before I could pull the lines from pump to Secondary filter. At this point I'm thinking the transfer pump failed, especially since the engine runs fine on the hand prime until that pressure is gone. I don't have vacuum or pressure gauges to properly diagnose so I do what I can with what I got. I just ordered a new pump. It's aftermarket but at $262 I was OK with that. I'm still going to pull the rest of the lines from injection pump back to make sure everything is good.
  9. Oxbow
    13,665
    141,668
    Nov 24, 2015
    When you get the new pump, compare it closely to the one that's on the truck now. If I recall correctly some of them had a longer plunger than others. You want to make sure it is the correct transfer pump.
  10. FreightyAK
    51
    42
    Aug 7, 2018
    AK
    10 4. Thanks for that.
    Oxbow Thanks this.
  11. wore out
    wore out Numbered Classic
    17,328
    215,211
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    See if the transfer pump inlet pulls your finger in a vacuum after either a helper or starter button roll it over a few times. It starts cuz your pumping fuel to it dies cuz it’s out. Take the transfer pump apart. Leave the diaphragms as they are in each piece. You should be able to blow through each of them one way only.
    Oxbow Thanks this.
