3406C to 3406E
Discussion in 'Experienced Truckers' Advice' started by Jasonar15, Jan 29, 2022.
  1. Jasonar15
    Jasonar15 Medium Load Member
    669
    519
    Aug 6, 2017
    I think my 3406C has called it quits after 2.3 million miles. Lifter rotated and damaged the cam and waiting to see if the lifter bore is damaged meaning block will be bad (What I was told from dealership). Mawk industries are out of business so does anyone know who I can get conversion from? With the C model having some electronic control i am hoping I can convert. Or any other idea would be appreciated.
  3. 062
    062 Road Train Member
    6,333
    33,973
    Oct 20, 2013
    Kustom truck is the only one I know of and it’s going to be pricey.
    Maybe @wore out knows a work around.
  4. AModelCat
    164,893
    Build your own harness. Get the pinouts for the truck side of the ECM and wire everything needed into that plug.
    Caterpillar Cowboy and Last Call Thank this.
  5. Jasonar15
    669
    519
    Aug 6, 2017
    So find out what pins run wbat on the current plug and match them for engine functions?
  6. wore out
    wore out Numbered Classic
    17,357
    215,545
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Kustom truck has one. From PEEC controls to E is an easy deal though
    exhausted379 and 062 Thank this.
  7. Jasonar15
    669
    519
    Aug 6, 2017
    Would you go e model or something different? Also could it be changed to a 12.7 Detroit by harness?
  8. wore out
    17,357
    215,545
    Jun 5, 2013
    I would go E model but I’m fond of CAT and biased. Detroit or even N-14 would go without a lot of headache
    Fact is if it was me I would build a mechanical B or C and run it.
  9. Jasonar15
    669
    519
    Aug 6, 2017
    This one has 2.3 mil on the clock. It’s been a good engine.
    I’m hoping the block isn’t bad. But if it is I might go back same engine. Lots of options and I’m just waiting on final answer if block is bad or not.
    wore out Thanks this.
  10. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Turn that PEEC back to a B model
    mtoo Thanks this.
  11. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    X2 nothing better than a mechanical cat
