3406e 5EK
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Tony2232, Mar 25, 2025.
  1. Tony2232
    Tony2232 Bobtail Member
    7
    8
    Mar 24, 2025
    Witch e logs are compatible with the 6 pin 3406e cat engines on todays market? I ordered the Garmin elog from Amazon it said connected but wouldn’t automatically change duty status to driving when truck was moving stayed on duty the entire time.
  3. ‘Olhand
    ‘Olhand R.I.P.
    6,750
    16,655
    Jan 18, 2011
    Why would you need an Elog w/an exempt engine??
    Diesel Dave and Sons Hero Thank this.
  4. Sons Hero
    Sons Hero Road Train Member
    4,089
    44,580
    Jan 8, 2021
    Indiana
    you want an exempt truck, and then decided to mess around with an Elog? Are you leased onto somebody that requires an e- log, why don’t you run paper?
    Iamoverit Thanks this.
  5. Tony2232
    7
    8
    Mar 24, 2025
    The company I’m trying to get on with requires e logs so idk if it will work with my truck or if I need to buy a newer truck
    Sons Hero and Iamoverit Thank this.
  6. Tony2232
    7
    8
    Mar 24, 2025
    Company requirements for hauling hazardous materials.
    Sons Hero, cke, ‘Olhand and 2 others Thank this.
  7. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,963
    Oct 31, 2023
    5EK works perfectly fine on an ELD. If you're having problems then it's the ELD manufacturer's issue so I would contact them about it and/or have a conversation with your carrier on how to procede.
    D.Tibbitt, Tony2232, Sons Hero and 2 others Thank this.
  8. Tony2232
    7
    8
    Mar 24, 2025
    Thank you
  9. 07shaker
    07shaker Light Load Member
    211
    835
    Jan 12, 2013
    Tx
    We run Samsara on multiple E models, even run it on a B model.
    D.Tibbitt Thanks this.
  10. Tony2232
    7
    8
    Mar 24, 2025
    Thanks that’s good to know that’s actually the ELD this company is requiring to use. How did you get it to work on a b model did you have to hard wire everything?
  11. 07shaker
    211
    835
    Jan 12, 2013
    Tx
    I don’t know that detail. I’m not around that truck enough to know how it was done.
