3406E coolant filter retrofit kit ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Slow302, Jun 29, 2018.
  1. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
    A few months back i bought 99 T2000 with 3406E. This truck doesnt have coolant filter and i want to add one. Im using extenxed life coolant. Does anyone know part # for good retrofit kit. I heard Cummins makes some but all i could find is some kits for pick up diesel trucks
    Thanks
  3. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    if you're running cat ELC you don't need a coolant filter. fitting one only adds to the chance of a hose bursting or rubbing through draining the coolant mid trip.
    Rideandrepair, tj379 and mtoo Thank this.
  4. Slow302
    348
    117
    Jul 12, 2013
    MO
    Anything is better than nothing. I installed all new silicone hoses. So im good with that. I found out that my fuel/water separator uses Donaldson p174766 filter base and some T2000 have same filter base for coolant filter. So Donaldson P174766 with Wix 24070 or Cat 435-5142 filter is better than none
    Rideandrepair Thanks this.
  5. mtoo
    mtoo Road Train Member
    1,942
    4,526
    Jan 15, 2011
    Retired on bended knee
    Simpler is better, just my opinion.
  6. MV97
    MV97 Bobtail Member
    16
    Oct 12, 2020
    Hey have you been able to accomplish this retrofit? I want to do the same to my 1998 w900
  7. Rideandrepair
    17,572
    56,914
    Aug 8, 2015
    Filters aren’t needed. But if anyone wants one, I highly suggest using shutoff valves on both sides of it, before the hoses. so a leaking hose can be stopped. Also use an on demand supplement filter, as a safety net against corrosion.
