3406e low fuel pressure need help please
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bull hauler, May 8, 2013.
  1. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    We need the engine serial number to determine which fuel system you have
    SAR Thanks this.
  3. Me jones
    Me jones Bobtail Member
    7
    Nov 5, 2018
    Sorry to steal the thread but I have a question for mr Haney I have 1994 w900b kenworth a 3406 5ek I have replaced all the injectors with brand new not reman on and I have had the motor rebuild about 75k ago it has all new sensors and all new fuel system it carries 65lbs of fuel pressure at a idle and 85 goin down the road I am having a problem with it acting like it is cutting out like it is running out of fuel or like it is a bad injector but the cut out test says they are good I am just about to the point that I am just goin to park the truck I was wondering if you might have a idea of what the problem might be and it is the original evidence it has 45,000 hours on it
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Sounds like you've done a lot stuff to correct the problem. You mention nothing about the power and grounds to the ECM and the engine harness on the engine and the one under the valve covers. Sounds electrical to me. Check the supply wires to ECM with a loaded circuit make sure there not weak .
    Intothesunset Thanks this.
  5. 062
    062 Road Train Member
    6,288
    33,827
    Oct 20, 2013
    If you figure it out post the solution. I’m having the same problem. Replaced the cam sensor that helped a lot, but has a hiccup in a hard pull over 1600
  6. Me jones
    7
    Nov 5, 2018
    I have replaced all of the engine wiring harnesses Evan the one in the rocker box and all the sensors are new and I have checked the engine hot wire and ground they are good
  7. Me jones
    7
    Nov 5, 2018
    Does anyone have mr Haney contact info
  8. 991lw
    991lw Bobtail Member
    13
    Email me at misu19720@yahoo.com,i have his nr.
  9. Me jones
    7
    Nov 5, 2018
    I have got in contact with him thank you for replying
    T800H Thanks this.
  10. Hughjazz
    Hughjazz Bobtail Member
    32
    17
    Feb 12, 2017
    Any chance you could share it with me also . Got an mbn that could use some unbridging
  11. united972
    united972 Light Load Member
    157
    22
    May 26, 2016
    sir do you still have his contact info can u message it to me neeed work on my c13
