3406e to 3406b
Discussion in 'Trucks [ Eighteen Wheelers ]' started by deereman6030, Nov 24, 2020.
  1. deereman6030
    deereman6030 Bobtail Member
    33
    Sep 27, 2012
    Have a good 3406b with recent inframe in a t600. Wanting to put that in western star with 3406e. How would one go about getting the gauges and all working? Any help on the swap is appreciated
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I put a Cummins big cam in my 95 Freightliner in place of the electronic series 60.
    Too much to list.
    You can p.m. me with questions if you like.
    Brettj3876, MACK E-6 and 650cat425 Thank this.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Most of the gauges are mechanical speedo and tack is the only problem
    650cat425 Thanks this.
  5. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Speedo would be off the trans. I think tack would be the only one that would be different. Everything else is mechanical I think. And tack wouldn't be hard
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Hanging throttle pedal and linkage will be harder than gauges. Need a donor truck.
  7. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    Get a mechanical tach and speedo for the Star. They are the same size as the electronic ones and will fit right in the dash. Hook up the cables to the engine and trans and route them out thru the firewall the same way they would have been on the older ones.
    The speedo you have in the Star now should work as long as you use the same pickup sensor and drive that is on the trans in the truck now. If you change trans. Remove and reuse its drive and sensor.
    black_dog106 and spsauerland Thank this.
  8. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    If he has the “Heritage” cab any White, Autocar, or Diamond Reo with the same “Drivers/Corporate” cab will work as a donor. Pedals may not have the WesternStar logo but they should be the same layout.
    spsauerland Thanks this.
  9. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    Most of the fuel peddles are simple floor mounted like old Kw’s and pete’s. The linkage however could be a little over engineered and sometimes mickey mouse on some of them. The linkage goes through the floor and has a z-bar mounted on the outside of firewall connected to a straight rod to the pump. More parts than necessary imo.
  10. deereman6030
    33
    Sep 27, 2012
    Thanks guys I’ll start on it during thanksgiving
  11. wore out
    wore out Numbered Classic
    17,333
    215,252
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Oil pressure gauge should be manual in both rigs. Be sure to use the sending units from the truck you are putting the motor in, that will insure the gauges read accurate. The speedo comes off the trans. The tach is read off a speed sensor that reads off the flywheel most likely, the B should have a place for that to screw right into. As said earlier getting a throttle pedal is going to be the hard part......
    I'm a B model guy to the core, that said I would fix the E if possible they are a way better platform
    cke, Oxbow, swaan and 9 others Thank this.
