379 front clearance lights not working
Discussion in 'Peterbilt Forum' started by Bdog, Dec 4, 2015.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    On my 2007 379 my front clearance lights (the ones in the same housing as turn signals) are not working on either side.
    I checked and bulbs are good and no voltage to the light socket. The fuse I assume is the same one as the roof top and rear clearance lights? I pull it out they go off. The turn signals work up front but no marker lights. Any ideas?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,567
    6,653
    Aug 26, 2014
    Work back from the lights and disconnect harness plugs as you find them. Head lights off, one turn signal and other lights on. The turn signal power is for testing your test light as you work back to find power then work forward to find open circuit. Also make sure the bulbs are grounded.
  4. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Hi Bdog, I went out to my 06 Pete 379 and checked my fuses, should be the same as yours, and I pulled the circuit breaker on the one that says 20 amp tail/stop lht, while my turn signal lamps were illuminated and they turned off. The cab lights still worked, but rear marker lights had quit too. I think you might want to check that circuit breaker. So on mine that circuit breaker ran the rear marker lamps and the two turn signal clearance lamps up front. Hope this helps.
    Bdog and Oxbow Thank this.
  5. Bdog
    1,057
    877
    Nov 6, 2014
    I checked and I have the same circuit breaker. With it in my tail lights work but no fronts. Pull it out the rears turn off. I assume they are on the same fuse.
    I guess time to start tracing wires. Heck I have a switch for fog lights but don't have any. I see the wires for them behind the bumper. I might just tie the front clearance lights to the fog light wires behind the bumper if it is too tricky to figure out.
  6. On A cloud 99
    On A cloud 99 Bobtail Member
    I've got a 99 peterbilt 379exhd doing same freakin thing. All marker lights work but ones on headlights. Fuses fine and relays fine. Turn signals work perfect just no running lights beside headlights. Pulled headlights out checked wires and installed led turn signals. Just clear turn signals. Had yellow led turn signals on before and had same problem. They worked fine on turn signals but no marking lights on them.
  7. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Trace the wires back from the headlights. They go to a connector under the radiator then back to the firewall
    They tend to get pinched around the hood hinges
  8. Pinkybuster
    Pinkybuster Bobtail Member
    8
    Feb 19, 2020
    I have been fighting this on a 2001 379.
    I found it to be 2 bad relays on one side each and the flasher relay for the LEDs. The LED one had a burnt wire end. The headlights would be on but low beam one side both on other. Swapped 3 relays and now high beam..low beam..and running lights. Funny thing is now my running lights come on with headlights or with clearance lights. Didnt before. I'll take that since everything else works fine so fa..r it's a pete so I'll await the next issue.
  9. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    Why would anyone mount clearance lights on their headlight housing? Thats pretty weird
  10. Pinkybuster
    8
    Feb 19, 2020
    What are you talking about? If it's my post it clearly says with running lights or clearance lights but never insinuated that they were the same or same location...
    sjreiff2018 Thanks this.
  11. RocketScott
    579
    949
    Apr 10, 2013
    Kentucky
    I think he's talking about the OP. Clearance lights are on the roof, marker lights are with the turn signals...
    Chubby Fly Thanks this.
