379 key tumbler replacement
Discussion in 'Peterbilt Forum' started by Cajuncowboy654, Oct 15, 2019.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    Ordered a set of replacement lock tumblers for my 05 379. Came with 2 doors and ignition
    Anyone know of a kit or part number that would come with 4 doors and ignition?
    My sleeper box doors are different keys and I'd like to swap them to be the same, cant repin them unfortunately without ruining the lock.
  3. Coolbreezin
    Coolbreezin Medium Load Member
    410
    440
    Jun 11, 2016
    Florida
    I ordered a 5 pack from Rush Peterbilt in Jacksonville, FL. Dont recall cost.
    Cajuncowboy654 Thanks this.
  4. Cajuncowboy654
    138
    34
    Jun 4, 2019
    Thanks, my local dealer told me this one was a set of 5 when I picked it up he said this is all they had.
    Gonna call around a few others see if I can get a set shipped
  5. Cajuncowboy654
    138
    34
    Jun 4, 2019
    I found some. Ordered online from a site, can order while set of 5 or just individual lock tumbler. you can give them your key code when you order and they will key the lock to your code so no need to order a full set for one bad lock.
    Not sure if this is allowed and if not I apologize but the site is freightdefense.com
    They have them for all trucks
  6. Roadscilz
    Roadscilz Bobtail Member
    6
    Did you ever replace the drivers door lock ? I want to replace my new to 06 379 door lock but don't seem to see much inside the door that connects to the lock cylinder
  7. bad-luck
    bad-luck Road Train Member
    3,464
    6,390
    Nov 16, 2013
    Baltimore, Maryland
    There is s clip that holds the lock cylinder in place.
  8. Roadscilz
    6
    How do you find the key code where is it located?
  9. Roadscilz
    6
    Found out their on the side of the lock cylinder or ignition switch cylinder guys if this helps anyone also if their the original lock cylinders peterbilt can match from the Vin #
