379 Pete 3406e problems
Discussion in 'Peterbilt Forum' started by DuesyJ29, Jan 31, 2017.
  1. DuesyJ29
    DuesyJ29 Light Load Member
    78
    35
    Jul 19, 2013
    Dallas, Texas
    I have a 1995 Pete 379 with the 3406e in it and I've been experiencing an issue. I have a 15 over trans in and when running through the top gears, at about 1800 to 2000 revs I get a stop engine and check engine light. As soon as I up shift or drop into neutral the problem magically goes away. I thought it might be overheating so I checked the water level and that was fine. I'm wondering if it could be the trans overheating or maybe something happening when the turbo spools up? Any ideas?
    Thanks
    MS
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Why are you running so high in the RPM's?? Im guessing it might be telling you its time to upshift. Its not a honda ya know.
  4. pigeon river trucking
    pigeon river trucking Light Load Member
    132
    99
    Jan 1, 2016
    michigan
    Sounds like engine over speed
    KB3MMX Thanks this.
  5. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Pull the codes and you will know.
  6. Driveone
    Driveone Light Load Member
    53
    10
    Oct 26, 2011
    South Carolina
    That's way to high engine speed for a cat good luck.
    Caterpillar Cowboy and KB3MMX Thank this.
  7. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    I agree. 1800 should be more than enough. I run 120,000 lbs. everyday and I have no probs at that rpm.
    KB3MMX Thanks this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Man that's screaming that poor kitty !!
  9. Oxbow
    Oxbow Road Train Member
    13,800
    143,308
    Nov 24, 2015
    In his defense, with a 15 over and a 600 RPM split sometimes you gotta run it just a little bit higher than the engine likes in order to get to the next gear.
    If it is running up to that RPM under power and not going downhill then I doubt it would be over speed.
  10. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    608
    Nov 11, 2010
    Wyoming
    Never knew that the check engine light doubled as a shift light!
    Oxbow Thanks this.
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Need more info, overheating. Dont you have a coolant temp gauge? Of all the cats I have owned I never went above 1800 rpm. With the truck engine off turn the key on but don't start it. With cruise switch off hold resume switch up for a few seconds then let go of it. Watch the check light and count the flashes. Example- 5 flashes then a pause then 5 more flashes means no active codes.
    WyoVac and Oxbow Thank this.
