379 pete sleeper heat and a/c problems
Discussion in 'Peterbilt Forum' started by coulds, Apr 24, 2013.
  1. coulds
    coulds Bobtail Member
    24
    Richmond,Va
    Yes it works o all three speeds in the AC position but it doesn't i the heater position I was wondering if the switch is bad or is there a relay that is bad.
  3. blade
    blade Heavy Load Member
    881
    647
    Jan 30, 2009
    Some where, Mo
    You ever figure out the issue @coulds
  4. thejudges69
    thejudges69 Light Load Member
    249
    316
    Aug 22, 2015
    Did you replace the pressure switch in the sleeper HVAC box? It's connected to the bottom of the expansion valve. It's got to have power to it. Make sure you have power to it and that's it's clicking on and off. It if doesn't come on it won't allow freon into the evap core. I'll post a pic when I get back to my truck.
    Are the freon lines getting cold at all?
  5. thejudges69
    249
    316
    Aug 22, 2015
    Oh and there is a temperature rheostat the 379 sleeper. When you turn the temperature to cold or hot it will turn the blower motor on and off. The rheostat it part of the temperature control switch.
  6. Slowdust
    Slowdust Bobtail Member
    Where is the expansion valve location in 379 pete
  7. amberfeldt
    amberfeldt Light Load Member
    140
    150
    May 20, 2019
    Minnesota
    Did you replace the switch in the control panel in the sleeper?if so how did you access it? did you only have to remove the storage compartment above the switch counsel ?
  8. thejudges69
    249
    316
    Aug 22, 2015
    Depending on if you have a top bunk or not makes a difference.
    IF you have a top bunk then the controls are against the from cabinet facing down at the mattress, take the grey or tan cover off and you have full access.
    If you DON'T have a top bunk the part under the cabinets that's roughly 3' long comes off and you have full access to the controls that way as well. You shouldn't have to remove the cabinets at all..
  9. amberfeldt
    140
    150
    May 20, 2019
    Minnesota
    Ok ill look it over some more thanks
