379 power divider valve
Discussion in 'Peterbilt Forum' started by project359, Nov 23, 2020.
  1. project359
    project359 Bobtail Member
    31
    9
    Oct 21, 2019
    Spotswood,NJ
    Good morning. I was wondering if anyone knew the technical term for the air valve mounted on the top- fwd-driver side of the trans for the power divider.Has 3 or 4 airlines going to it. When i push the button to lock the rears I have a bad air leak and need to change it. Im trying to look it up but no luck with its actual name.
  3. SmallPackage
    5,827
    18,683
    Dec 20, 2019
    Marion Texas
    Slave valve. A-4688 and A-5000 are two #’s that come to mind.
    Power divider valve is on the front differential for the inter-axle lock. Usually only has one 1/4” or #4 hose going to it.
    okiedokie Thanks this.
  4. spindrift
    spindrift Road Train Member
    3,235
    12,916
    Dec 2, 2014
    Texas
