379 replacement flooring
Discussion in 'Peterbilt Forum' started by mile marker 27, Feb 13, 2022.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    ‘87 379EXHD, dump truck. Ok, as said, it’s a dump truck but I want something that decently nice. Rubber or hardwood is probably the ticket and I’m leaning more towards the rubber. I plan on stripping all the bits of existing flooring out and it had the rubber over foam, which I like. What do y’all recommend and where do I get it?
  3. bad-luck
    bad-luck Road Train Member
    3,465
    6,391
    Nov 16, 2013
    Baltimore, Maryland
    Hardwood would be a waste of money and not last for the type of work you do. They make an aluminum floor which would hold up better, and you could have it painted the color of your choice. 12 Guage Customs has aluminum floors.
    mile marker 27 Thanks this.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
  5. pavrom
    pavrom Road Train Member
    3,238
    7,499
    Apr 29, 2012
    NE illinois
    ...i was always thinking about putting vinyl penny flooring in my truck
  6. wore out
    wore out Numbered Classic
    17,582
    219,842
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I went to tractor supply and bought a horse trailer rubber mat for a truck I flipped. Turned out real snazzy and still lols good a year later. 10 times warmer that the hardwood that’s in mine
    RubyEagle, Oxbow, NightWind and 2 others Thank this.
  7. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    Mines worn through between the seat and pedals. The left side of the gear shift cover is exposed and drafty there too.
  8. DM0311
    DM0311 Bobtail Member
    17
    11
    Jan 30, 2022
    I agree with the guys above, you probably want rubber. Especially in a dump. That said, if you decide to do wood... don't use wood. Lowes, home repo, and all of them have plastic flooring that looks like wood. I have it on my house. Is tough as hell, looks good but pricey. However I ran the cost on doing my pete with it and it was only going to be about $50. Also buy auto insulation to put down before you put anything down. Make a lot of difference. I bought 80mmNoico... it's decent. You can buy better... you'll pay more. I probably should have gone with a higher brand but I'm putting insulated carpet back down
  9. NightWind
    NightWind Road Train Member
    2,718
    19,174
    Nov 11, 2006
    Sunny South, AL
    @wore out Did you have sound proofing/insulation from the old carpet/flooring or how did you soundproof/insulate under the mat? A picture would be nice if possible.
    Oxbow and wore out Thank this.
  10. wore out
    17,582
    219,842
    Jun 5, 2013
    My original foam mat was in pristine condition. So I left it as is after a good cleaning
    NightWind and Oxbow Thank this.
