379 sleeper blower
Discussion in 'Peterbilt Forum' started by spindrift, Aug 3, 2020.
  1. spindrift
    spindrift Road Train Member
    3,237
    12,917
    Dec 2, 2014
    Texas
    Hoping to find a troubleshooting tree of some sort. The sleeper blower stopped working. The obvious first step, at least for me, was to check the fuse in the main kick panel. That was good. Where should I go next?
  3. SmallPackage
    5,847
    18,750
    Dec 20, 2019
    Marion Texas
    Check the switch and wires up to the motor. If look good than the motor would be next step. Sometimes tapping on the motor may get it rolling again for awhile till it gets hot again. Then you will know for sure it is motor.
    Did you smell anything burnt when it stopped or did it work and you shut it off like normal and then it wouldn’t come back on later when needed?
    Rideandrepair and spindrift Thank this.
  4. spindrift
    3,237
    12,917
    Dec 2, 2014
    Texas
    It has been working fine. Today I noticed that it wasn't getting as chilly as normal in the cab and I just chalked it up to another Texas scorcher. But then I had to go into the sleeper to retrieve some paperwork and that's when I realized it was warm and no air was coming out of the vents. Didn't smell anything unusual.
    Rideandrepair Thanks this.
  5. SmallPackage
    5,847
    18,750
    Dec 20, 2019
    Marion Texas
    In 15 years I’ve had to replace the motors 3 or 4 times. They run as long as the big engine is running so they work pretty hard down here. I think they were around $40 each time but it’s been 5 years since I retired that truck.
    I’d bet that the motor just got tired and you have no other problem with it. They most of the time will just quit without blowing a fuse or harming the switch or wires.
  6. spindrift
    3,237
    12,917
    Dec 2, 2014
    Texas
    Before I go ahead and embarrass myself, there's only the one blower under the mattress platform at the control panel end, correct??
  7. Rideandrepair
    17,587
    56,970
    Aug 8, 2015
    Yep, motors shot. Super Trucker Outlaws don’t need air in the bunk, cuz they never sleep. Change it, worst thing that can happen, is you’ll have an extra, when it does go bad. It could be the switch. My Shaker burns through them often. Even melts the plug. Might want to visually inspect that, but probably just a bad motor. It’s probably been running slow for a while, just didn’t notice. Same reason my switches burn up, tired blower motor.
    spindrift Thanks this.
  8. spindrift
    3,237
    12,917
    Dec 2, 2014
    Texas
    This Super Trucker does. He was raised by his Mama!
  9. Rideandrepair
    17,587
    56,970
    Aug 8, 2015
    And a fine Lady I’m sure. It’s an easy fix. Prices for mine have gone over $100 at dealer. But I saw one on line a lot cheaper. Good Luck. Probably need a small torx head to change it.
  10. spindrift
    3,237
    12,917
    Dec 2, 2014
    Texas
    Looks to have been changed out before. I count three different screw heads, lol.
  11. SmallPackage
    5,847
    18,750
    Dec 20, 2019
    Marion Texas
    Don’t toss it till you have the new one in your hands. You may have to reuse the old squirrel cage.
    spsauerland and Rideandrepair Thank this.
