379 sleeper dome light
Discussion in 'Peterbilt Forum' started by Bdog, Jan 18, 2016.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    The big rectangular fluorescent light in the center of the sleeper roof. When I bought my truck used it was not there. Talked to a parts guy and he said they are very problematic, expensive and would not recommend buying the stock one. He said many guys make a wood plate to cover the hole and mount some led's on the wood in place of it? Anyone done this and have pics or have other ideas?
  3. 062
    062 Road Train Member
    6,333
    33,972
    Oct 20, 2013
    Search the forum,GrapeApe posted a link to a light that fits in the housing,for like $30.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    You can find a good used OEM replacement at any Truck Salvage Yard. The reason the OEM replacements are so expensive is because (besides the fluorescent light bulbs being replaceable), there are no User Serviceable Parts inside, so when it takes a dump, it's time to throw it away and replace.
    I bought a used one at a Salvage Yard for $30 or you can try e-Bay. A new OEM one will set you back at least $200.
    I would suggest obtaining the OEM part number and try a Google search using it to see who might have one.
  5. josh polk
    josh polk Light Load Member
    142
    64
    Dec 20, 2015
    Bowie TX
    Those lights have a mind of there own will turn there selfs on and drain ur battery's
  6. Luwi67
    Luwi67 Heavy Load Member
    751
    485
    Oct 24, 2012
    Long island
    If you come across an original light that has gone bad you can remove the florescent parts and use stick-on LED strips like this:
  7. josh polk
    142
    64
    Dec 20, 2015
    Bowie TX
    image.jpeg Yea I'm a lover for led strip light
