379 trailer pig tail problems
Discussion in 'Peterbilt Forum' started by 70white, Feb 2, 2014.
  1. 70white
    70white Bobtail Member
    6
    I have a '90 379. when I turn the running lights on, I do not have power to all my trailer lights. I checked the pig tail connection at the truck and I think I am supposed to have power on both black and brown wires. I only have power on black and nothing on brown. Is there a fuse in the panel that would cause this or do I need to look somewhere else?
  3. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    Is it a portion of your running lights that are not working??? What make of trailer??? Van-Reefer-FB????
  4. 70white
    6
    yes it is a portion of the running lights. the brown wire in the plug on the truck side has no power.
  5. wore out
    wore out Numbered Classic
    17,430
    216,928
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Look under the dash on the left side of steering column. You will see a black cable come from outside to inside that is your trailer harness. The older Petes are notorious for heat right there causing the insulation to be brittle and flake off, some times the wires them selves break, but usually just touch one another and throw a breaker. Also on the light switches they are bad to over heat and not make connection on the inside of the switch when turned on. First make sure you have power in to all three switches, them turn all three on and make sure you have power out of all three. One of the switches powers the black wire and some of the truck lights, the other powers the brown wire and the remaining truck lights.
    70white Thanks this.
  6. 70white
    6
    Three switches?? Mine only has 2 switches. 1 for headlights and the other for running lights
  7. wore out
    17,430
    216,928
    Jun 5, 2013
    Should be the first three switches on the top row to the left first is head lights the second two is markers. Sorry when I typed that I realized my goof, your right only two marker switches the headlights don't effect the markers.
  8. waawho
    waawho Bobtail Member
    my uncle had same problem.he ran a jumpper wire from the black to brown inside of pigtail and now all his works.i don't think i would use very big wire for jumper though.
  9. wore out
    17,430
    216,928
    Jun 5, 2013
    While that will get you out of a bind, it is not a permanent solution. It puts the amp draw of 2 circuits on one which causes heat. The old breakers just don't protect like fuses do, I have seen many a switches justb melted down on the back because of this. But I'm sure it was done long ago and no problems, I just wouldn't chance it.
  10. RiskyBusiness
    RiskyBusiness Light Load Member
    95
    33
    Dec 28, 2013
    Tyner, NC 27980
    This will work, I've done that myself till I could get somewhere to get a new pigtail. As your looking at plug end take a piece of wire strip both ends of sheathing and put wire into #2 & #6 then plug your pigtail back in and all your lights should be working again. Remember this is a temporary fix.
    This diagram may not be exact to yours but the position of jumper wire should go into same holes on your pigtail, diagram just to show you which ones to put it in.
  11. 70white
    6
    I ran the black and brown wire together this morning to get my lights working for now. Now I have to find the problem in the cab and fix it
