I have two 387 mirror questions.
On the drivers side mirror, the temp. gauge has just the two dashes showing.
When you first turn the key, it looks like it wants to start, but then only shows the dash marks.
Anyone seen this before and have a solution for it ?
The passenger side hood mirror is hard to see. Has the normal round mirror with mount in the middle.
Anyone have any upgrades ( differrent type mirror, differrent brackets ) to make it useable,
Thanks in advance,
Discussion in 'Peterbilt Forum' started by Ludwig, Jan 16, 2013.
The driver side mirror............It probably has something to do with the O/S tem sensor which is usually located in the front of the truck behind the grille. The nose mirror should be able to be raised up by loosening the nuts on the mirror brackets.
I belive the temp sensor is in the mirror atleast it is on the 379
There is a little lever at the bottom of the glass that you can slide with a screwdriver then the glass will come out. On the back of the thermometer there are come buttons to change it from C to F or turn it off. Mine was acting up one time and I turned it off then back on and it straightened it out. The sensor is the little black tip on bottom of mirror housing
Ludwig Thanks this. -
Well,
I pulled the mirror and tried the button and it went to off to double dash to double dash and back to off.
I would guess my unit is broke. Anyone know if you can meter the sensor to know wether it is good ? -
I know this is an old Post but my truck had the same problem. The oat sensor ( temperature sensor is in the bottom of the mirror) mine had corrosion in the wires. if you're lucky enough to be able to solder the wires together again it will work, if not you have to buy the whole assembly which is the mirror included. Pn 108p/m015729s.
