389 Coolant Sensor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dirthaller, Oct 17, 2023.
  1. dirthaller
    dirthaller Road Train Member
    1,137
    13,698
    Sep 22, 2011
    Coloratah
    When my Peterbilt 389 Coolant sensor went out about 250,000 miles ago, I simply unplugged the sensor at the tank and the buzzer went off. It just threw a code until I replaced it (I put a whole new tank on it).
    Today, the low coolant buzzer went off……coolant plenty full…..so I unplugged it and the buzzer won’t go off. I tried the paperclip trick too. Nothing makes the buzzer go off.
  3. Goodysnap
    Goodysnap Road Train Member
    3,784
    9,223
    Jul 12, 2017
    Pull test the wires within the first foot of the harness. Broken copper inside the insulation is common up near the tank due to vibration. Spread pins at the sensor connector are also common.
    dirthaller Thanks this.
  4. M22 rockcrusher
    M22 rockcrusher Road Train Member
    1,347
    4,152
    Nov 21, 2020
    Get a telescoping magnet and put down the tank sometimes the float sticks even new one's there's enough metal there to unstick it its worth a try worked on my 579.
