389 Steering Problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ebb75, Aug 28, 2012.
  1. Ebb75
    Ebb75 Bobtail Member
    5
    Hi im new to the forum. One of our petes has a steering issue that we cant figure out. Its a 2012 389. Has steering axle air bags. Seems to jerk the wheel pretty good when any bump in the road is hit. All steering components are tight. Replaced steering box. Tried new steer tires. Tried different air bag pressure in the front. Nothing is working. Just wondering if anyone else had this problem. As none of the other trucks in the fleet do this.
  3. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    wowsers 2012!!! truck with issues holy crapper...
    you replaced gear box? wow do the other trucks in fleet have front steer axle airbags? could be just the normal feel of the airbag front suspension.Although i drove a 379 pete with front air bags and never felt this before.
    maybe its a manufacturer recall.
    Ebb75 Thanks this.
  4. Ebb75
    5
    Yes we have another with front air bags and dont have this problem. Dont know what else to try. Maybe the pump off the engine that feeds the steering box is surging or something. Its a puzzle to everyone.
  5. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    Make sure the axle is not in backwards. I know of a older truck that had the axle replaced and they put it in backwards. He drove it for a month like that. He said it never felt right and that it was jerky.
    I am almost positive that the ID tag is supposed to be toward the front. Maybe check your other trucks to be sure.
    KB3MMX and Ebb75 Thank this.
  6. Ebb75
    5
    Thanks DL550CAT will check it out.
  7. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    If you have a Hendrickson Airtek axle, this is one of the characteristics of this axle. It is more "springy" than a regular cast axle. Hendrickson was placing a composite thrust bearing on the left side of the axle to help dampen the shake you are experiencing. You will need to check if one side thrust bearing looks different than the other side, if they are both the same chances are you need one installed. We had one customer a few years ago with brand new unit with an Airtek and we replaced everything bolted to that axle. We played with the caster settings and nothing changed nothing. The rep from Hendrickson had to come down and road test the unit. After he drove it they authorized us to replace the whole beam. The beam wasn't tempered correctly. After that it was better, but still had some shake. We ended up installing a steering stabilizer and the customer was happy after that. We still see that same truck today, with a different owner, but everytime I drive it it still has that little shake.
  8. GP1500SC
    GP1500SC Light Load Member
    91
    32
    Sep 10, 2011
    mo
    Is the ride height set correctly?
    its probably not the problem, but is a easy check and it will cause bump steer if is to far off.
    the bar off the pitman arm going back to the axle should be level.
  9. Ebb75
    5
    Hmmm good to know. Maybe it will always have that little shake. Ill do some investigating. Thanks for everyones input. Greatly appreciated.
  10. Ebb75
    5
    The drag link should parallel to the ground is what your saying GP1500SC?
  11. GP1500SC
    91
    32
    Sep 10, 2011
    mo
    Correct, except on the previous post I left the little word about out in front of level
    A rise to the front is normal and necessary , especially with springs as ride height is dictated by load, air ride not so much.
    The higher the rise / angle the more the the truck will steer to the right as the body goes down in a bump situation, or body roll.
