4 ft firestik with magnet mount??
Discussion in 'CB Radio Forum' started by carg618, Feb 8, 2018.
  1. carg618
    carg618 Bobtail Member
    46
    14
    Feb 8, 2018
    i have a firestik 4ft and a heavy duty spring. I bought a workman pm5 magnet mount and i plan to put it on the trunk of my car or maybe the roof. will this mount hold going 60mph or faster or if i hit branch. If not, what is a good mount?
  3. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    The product description states that it works best with base loaded antennas like a Wilson 2000, a tri- mag mount would probably be better for top loaded and heavier antennas. When I had a F150 ( metal roof) I used a Wilson 1000 magnet antenna and was always pleased with the performance.
    carg618 Thanks this.
  4. carg618
    46
    14
    Feb 8, 2018
    im just going to use and firestik hood trunk mount. itll hold better
    wolverine11 Thanks this.
  5. wolverine11
    1,628
    1,234
    Apr 1, 2015
    Does Firestick have adjustable stinger on top so you can set swr?
  6. carg618
    46
    14
    Feb 8, 2018
    it can adjust yes. But i dont have an swr on my cb and i aint buying one haha
  7. MudduckDx
    MudduckDx Bobtail Member
    I have a Tram Triple 5, mag mount on center of my trucks roof, with a President Alabama on it, works absolutely awesome. When I switch to my 4'firestick, it stays put at 75mph and smokes the frequency. I like both antenna because they are NOAA weather alert capable. If you get a good SWR match , it is vital to a good broadcast and ya won't blow your finals.
  8. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    I can't comment on a Workman pm5 magnet mount's ability to handle wind and overhead obstructions because I've never used one. I have used several types of Wilson and K40 magnet mounts ranging from 35 to 63 inches in length, and I can say that I have never had one of them fail at any legal highway speed or in high winds or from hitting tree branches overhanging the streets. I suppose they could fail if someone installed an overly long or top-heavy stinger on them, however.
  9. MudduckDx
    Hey Mr Cargo618,
    I failed to mention, I know those 5 inch single magnets are kinda dicey for a thicker rod /fiberglass like the 4 foot firestick, perfect for a 2 footer with the medium duty firestick spring, but ive heard the 5 inch get a little sloppy in the trees with a thin 40 inch whip, so I wouldn't do that nice 4 foot firestick unless you use the triple 5 magnets, which once you stick on your trunk, roof, you will need an arm lile Popeyes to get it off, Lol. Cheers
  10. Powder Joints
    7,983
    8,384
    Sep 25, 2007
    Rosamond, SoCal
    Yes no problem, I have used that mount with a diamond tri band and it held
