4300 2004 won’t start
Discussion in 'International Forum' started by Ldentm, Feb 19, 2023.
  1. Ldentm
    Ldentm Bobtail Member
    The truck ran fine on friday pulled in the shop parked for the night, next day would not turn over Replaced starter cables and batteries, still won’t start. Checked key switch, test ok. Don’t know what to do next !
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,050
    2,268
    Dec 15, 2021
    Try tapping on the starter with a hammer.I had one that got some corrosion from the salt on the road.
    Got it started and replaced the starter back at our shop.
  4. Inderjit
    Inderjit Heavy Load Member
    774
    740
    Sep 17, 2017
    What engine do you have? Dt466e the starter relay grounds through the engine ecu. If the engine ecu has lost its clean power supply it will not crank.
    AModelCat Thanks this.
  5. AModelCat
    165,579
    That thing got a safety switch on the clutch?
  6. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Auto trans, is it in neutral?
  7. Star Rider
    Star Rider Road Train Member
    1,821
    19,821
    Sep 23, 2019
    Try jumping the starter solenoid on the starter , it will narrow it down. If it cranks then the starter is not the problem. If it doesn't go farther up line.
