4700 drive tires
Discussion in 'International Forum' started by wlhequipment, May 14, 2026.
  1. wlhequipment
    wlhequipment Light Load Member
    56
    24
    Aug 16, 2022
    denver, co
    I think I made a mistake. My 4700 had Michelins on it, and I needed new drives. Moneys tight so I bought a set of Sailun S753s. Chinese tires. They actually got decent reviews. The truck runs 2 or 3 days a week max, and I'm strictly local, and I'm loaded fairly constantly at around 18K. Mechanic truck, so load really doesn't change much. I didn't think the tires would make that much difference. I think I screwed up though. With the old drives, that thing tracked straight as an arrow on the highway. Unless I was in ruts or crosswind or something. Always handled just fine. As soon as I put these Sailuns on, now it "hunts" sometimes. The steering becomes real squirrelly and it wanders left to right slightly, like I just wore out a kingpin or tie rod end. I mean, it is possible I got worn steering components, but it drove straight on Thursday and on Friday after I installed the new drives, it wandered. Has that happened to anyone else? Install new drives and now it steers funny? These are 1/2" smaller in diameter than the Michelins but since the Michelins were so worn, I don't even notice a difference in 6th gear. Aggressive tread open shoulder because I'm on dirt roads sometimes. I don't even notice tread noise. Thanks
  3. wlhequipment
    56
    24
    Aug 16, 2022
    denver, co
    Well, as usual if I just waited a little longer, I'd sort it out. The answer was grease, sort of... isn't it always? I lubed the front end, and she ran straight as ever. So I guess that means I do have something loose up there. Or I should grease it more. Either way, I'm all good.
    JB7, Concorde, 1999 C12 and 1 other person Thank this.
  4. 1999 C12
    1999 C12 Bobtail Member
    37
    119
    Nov 5, 2024
    BC Interior
    We run agressive Sailuns on our walking beam dump. Good tires for the price.
    A good percentage of the log trucks here (tri-drive) use these tires in steep mountainous terrain with good results.
    Glad to here your truck is running straight!
  5. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    This is a little more common than you would think. New tires with big thick lugs will allow the truck to wiggle sorta of as it rolls because the rubber blocks in the treads are wiggling with the soft and think new rubber. Once a bit of wear and heat cycles goes through it, they will harden up a bit and that squirming sensation will diminish.
    Diesel Dave and AModelCat Thank this.
  6. wlhequipment
    56
    24
    Aug 16, 2022
    denver, co
    Good to know thanks!
