4700 electrical problem
Discussion in 'International Forum' started by Salvageguy, Aug 17, 2017.
  1. Salvageguy
    Salvageguy Bobtail Member
    Hey guys,
    I have a 97 model 470 dt466e rollback 7speed. Problem I'm having is no power windows,no temp controls,no wipers working. When I turn on key I get a constant beeping. Truck starts and runs fine and no beeping while running. I've check fuses in cab and see no wires broke or unplugged. Any help on this?
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Certain sections of the fuse panel is feed power by main power wires. They are red in colour and 10 gauge in size. There are several of them and all go to a main junction block in behind the fuse panel up by the clutch pedal somewhere up there. See if there is anything loose. Also, those trucks like to leak water from the windshield and water leaks down and corrodes that whole area.
    QUALITYTRUCK Thanks this.
  4. Salvageguy
    thanks. checking the ignition switch now
