48’ 40 Lowboy or 48 flatbed - tandem
Discussion in 'Ask An Owner Operator' started by 1mm3406e, Jan 28, 2023.
  1. 1mm3406e
    1mm3406e Bobtail Member
    28
    13
    Jul 13, 2019
    Any body have any knowledge of which of these trailers makes the best retes/profit? Thanks
    48 flatbed Or 40 ton tandem lowboy
  3. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,399
    Feb 8, 2022
    Raleigh NC
  4. W923
    W923 Road Train Member
    1,462
    4,557
    Feb 28, 2022
    I feel like it could go either way very sharply depending on where you are and who you know and what connections you have. I know that running a 55 ton 3 axle can be really good money with the right connections but some of my buddies run flats and make more money. I feel like they work a lot harder where as I work smarter as in plan much better because of load availability.
    Siinman, D.Tibbitt, Vampire and 2 others Thank this.
  5. 1mm3406e
    28
    13
    Jul 13, 2019
    Thanks bud
  6. abyliks
    abyliks Road Train Member
    4,300
    10,300
    May 2, 2010
    ludlow MA
    Are you moving your own equipment?
    if not, you’ll get a higher volume option for the flat
  7. 1mm3406e
    28
    13
    Jul 13, 2019
    Nope not moving my own equipment. Just tryna pick the best option. Thanks for the reply.
  8. Ruthless
    Ruthless Road Train Member
    9,431
    94,739
    Aug 28, 2010
    The City.
    Who do you know n what do they have to move? If you’re coming in fresh with no contacts & just using loadboard freight- probably keep busier with a flat. Success is really what you make it: how good you are at making a pitch, how much you already know about what moves when and from who, how well funded you are and how fast you can catch up on the learning curve.
    haycarter, Siinman, Cat sdp and 5 others Thank this.
  9. 1mm3406e
    28
    13
    Jul 13, 2019
    Yep coming in fresh and I don’t know anyone In the flatbed or lowboy scheme
  10. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Then go with a flat.
    W923, Old Man, 1mm3406e and 1 other person Thank this.
  11. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Flatbed till you learn. Lowboy will eat your lunch with no experience.
    W923, 1mm3406e and Jubal Early Times Thank this.
