48’ flat or stepdeck with ramps
Discussion in 'Flatbed Trucking Forum' started by Dadetrucking305, May 2, 2021.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    I recently got back into a truck and have been hauling Frac sand locally but eventually I want to get into what I like which is open deck freight.Which of the two is the better choice?
  3. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    Right now, I almost wish I had an all aluminum 53ft step with a Conestoga. Alot of light loads that are sometimes too tall for a flat.
    All depends on what you want to haul and what is available in your area you run. If you haul alot of steel, a Conestoga is sweet.
  4. Espressolane
    18,691
    117,154
    Take a look at this set-up.
    If you are serious, contact the OP on it @Ruthless
  5. Dadetrucking305
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    That’s a nice trailer.
    OLDSKOOLERnWV Thanks this.
  6. Ruthless
    Ruthless Road Train Member
    9,191
    91,272
    Aug 28, 2010
    The City.
    I got another one thats nicer f/s as well if you looking for a connie flat
  7. Dadetrucking305
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    So which is the better trailer?
    cke and Tug Toy Thank this.
  8. Espressolane
    18,691
    117,154
    For a faster response, use the @ user name.@Ruthless
  9. Ruthless
    9,191
    91,272
    Aug 28, 2010
    The City.
    ^what shooter said is the answer for flat v step
    What kind of work you have available to you/
    i have flats and steps: because i need both/ some of what i do requires a step, and other stuff, while i could figure a way to make it work on a step about every time, its a hell of a lot easier to load on a flat.
    unless you were asking which of my connies is nicer, in which case id say the newer one.
  10. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    Step decks can be a pita for doing building materials because of weight distribution. The only reason to get a step deck IMO is if you’re going to haul a lot of vehicles or tall loads. Of course this is only my experience. Other people who own step decks probably have a different view.
    I would start with a flat, then if I wanted to do other stuff get a rgn. 2 cents, take with salt.
  11. Dadetrucking305
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    I’m out of San Antonio and just got back into being an owner op after 2 years and currently hauling Frac sand in the oilfield but it’s a #### job.Too many hours for not enough pay.Before this I had a hotshot for six years so an open deck is what I like and still have a couple of customers that I can get loads from but I’m sure it’s not enough so I’ll be using the boards until I build by customer base up again.
    cke Thanks this.
