4MG 3406B jake brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 2, 2026.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    Jakes will pull engine all the way down until it stalls. I don’t have a “low” setting. The switch is either “off” or “high”.
  3. Oxbow
    Oxbow Road Train Member
    13,684
    141,938
    Nov 24, 2015
    If you touch the throttle or the clutch it kicks the jakes out, right?
  4. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    Yes.
  5. wore out
    wore out Numbered Classic
    17,432
    216,991
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    They are set up forward cylinders or rear. I’ll be honest just half of them are the most useless thing on the truck. With both working together they are the 2nd most useless thing on the truck. I’d run it
    ElmerFudpucker and Oxbow Thank this.
  6. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    Ok, woreout, I’m in your lane here. Should the jakes kill the engine, even if the accelerator or clutch, isn’t depressed? My old big cams don’t.
    MACK E-6 and Oxbow Thank this.
  7. wore out
    17,432
    216,991
    Jun 5, 2013
    At idle yes
    Oxbow and mile marker 27 Thank this.
  8. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    Well, I guess I’ll leave the mf’er alone. Now, I’m wondering why the BC’s I have don’t do the same? My electronic engines(12.7 and N14) don’t stall either but that’s electric fuel delivery.
  9. wore out
    17,432
    216,991
    Jun 5, 2013
    The electronic motors it’s in the ECM to shut them off under 800.
    It’s been a long time and I can’t remember what the name of this control box was it was an add on thing like king cruise. Only it shut the Jake’s off at idle.
    I flip my switch it’s just sorta 2nd nature to me
    MACK E-6, mile marker 27 and Oxbow Thank this.
  10. SmallPackage
    5,818
    18,639
    Dec 20, 2019
    Marion Texas
    Jakes will stall the engine out. Even a Cummins if it is wired straight to heads without throttle or clutch switch like many early one were. It will take it from 2200 rpm to shut down in a matter of seconds. My 25A’s on my 350 are just a on/off toggle and a 3 position toggle for 1 head or 2 heads, or all 3 heads.
    Oxbow Thanks this.
  11. SmallPackage
    5,818
    18,639
    Dec 20, 2019
    Marion Texas
    Many Old timers that ran the old two stroke Detroit's have said that they were the only engine you could leave the jakes on at idle. They would not stall the engine. Lol
