4MG Rebuild
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Oxbow, Feb 19, 2024.
  1. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    I’am not fond of aluminum frames one thing is bolts in aluminum add some years and corrosion and you earn every turn with the wrench when you unbolt anything I personally prefer Air leaf over air track especially if your off of a paved road
    Feedman, broke down plumber and Oxbow Thank this.
  3. Last Call
    7,568
    45,914
    Mar 15, 2021
    Lol I was thinking of another mentality unstable idiot :biggrin_2556: Not so much you lol
  4. Oxbow
    Oxbow Road Train Member
    13,783
    143,141
    Nov 24, 2015
    The rust jacking between the steel liner and the aluminum frame was actually starting to distort the frame flanges. Steel and aluminum don't play well together, especially with all the crap on the roads in the winter now.
  5. broke down plumber
    4,077
    32,186
    Jan 25, 2024
    gob it up with dielectric grease
    Sons Hero, Last Call and Oxbow Thank this.
  6. Oxbow
    13,783
    143,141
    Nov 24, 2015
    Oh, I forgot to share this:
    How in the hell did that bolt end up the temp regulator?
  7. Last Call
    7,568
    45,914
    Mar 15, 2021
    Yeah except you for got to bring that to Peterbilts attention lol
  8. Last Call
    7,568
    45,914
    Mar 15, 2021
    That’s a very good question @Oxbow I don’t believe it just fell in there
    That’s one for the books lol
  9. broke down plumber
    4,077
    32,186
    Jan 25, 2024
    Well ill try .
    Oxbow and Last Call Thank this.
  10. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    The the fretting isnt bad the deck cut will also fix liner fretting.
    If the fretting is bad enough decking the block wont fix it they will counterbore it to the first shim size usually .032. If the fretting is still there they will just keep cutting for a bigger shim. They will know how how much needs to be done.
  11. AModelCat
    165,739
    My brakesaver had loose o-rings inside the pickup strainer. Still scratching my head on that one too.
