1. EvertonP
    EvertonP Light Load Member
    156
    255
    Sep 10, 2022
    Why is the latest trend guys not raising the top back deck? With the cost of trailers now I’d fire a guy for having metal on metal contact going down the road for hours, but now all your tail lights are 6 inches from the ground.
    Hammer166 Thanks this.
  3. Banker
    Banker Road Train Member
    4,485
    14,354
    Aug 19, 2012
    I keep my top deck about eye level with 4 wheelers when MTY. Hopefully less chance they climb up on me in the event of a rear end collision and maybe they will see my taillights.
  4. EvertonP
    156
    255
    Sep 10, 2022
    see that makes sense to me. It literally takes 35 seconds to raise that deck up
  5. Banker
    4,485
    14,354
    Aug 19, 2012
    I have always been told you need to pin your decks even when MTY.
    carhaulerjeff and LBZ Thank this.
  6. ducnut
    ducnut Road Train Member
    2,683
    8,124
    Dec 31, 2010
    SPI
    Why do drivers run the deck fully elevated with a couple vehicles up top and nothing below? Saw one like that, again, today. F-150 up front and a Tahoe at the rear. I wouldn’t want my loaded weight all up high.
  7. Hammer166
    7,592
    27,721
    Aug 18, 2007
    ~8600+' and loving it!
    Fully elevated is just lazy, but you shouldn't run them too low with heavy vehicles loaded, as the shallow angle of the posts really increases the load on the lock pins.
    Also, remember that our empty weight is normally 43 to 44,000 lb. So a couple vehicles on top isn't going to change our center of gravity much. We often have to move Vehicles when partially loaded, but it's not for center of gravity reasons, it's to keep from getting too heavy on our steer axle.
    ducnut and Banker Thank this.
  8. Hammer166
    7,592
    27,721
    Aug 18, 2007
    Currently in carhaul, there's an over-fixation on loading time. Those guys will literally tell you it takes too much time to raise the deck and pin it, and then having to do the opposite to reload.
    They have obviously not ran in heavy icing conditions, which can cause the coil cord for the top lights to get weighted down and drag the ground, at least on Cottrell trailers.
