50% Random Drug Testing Rate Information
Discussion in 'Trucking Industry Regulations' started by MidwestGator, Jan 27, 2020.
  1. MidwestGator
    MidwestGator Bobtail Member
    44
    79
    Jan 9, 2020
    What Does FMCSA Increase To 50% Random Drug Testing Rate Mean For Fleets And The CDL Clearinghouse?
    In December, the Federal Motor Carrier Safety Administration (FMCSA) has increased its random drug testing rate from 25% of CDL drivers tested to 50%, effective Jan. 1, 2020.
    So, why was this change made?
    For the last four years the random drug testing rate has stayed at 25%. Now that more than 1% of drivers have tested positive in their FMCSA random testing, on January 1st, 2020, the rate automatically reverts to the 50% random testing rate.
    This rate increase was partially due to the legalization of recreational marijuana in many states nationwide creating a more widely accepted stigma around weed and the recently added (in 2018) semi-synthetic opioids to the random drug test panels that are generally taken as pain pills.
    How This Increase Affects Fleets With CDL Drivers?
    FMCSA estimates there are 3.2 million CDL holders operating in interstate commerce and 1 million CDL holders operating in intrastate commerce. With this population and 50% of drivers to be tested, approximately 2.1 million random controlled substances tests will need to be conducted in calendar year 2020.
    With more drivers being test, more drug tests and results will have to be performed, likely slowing down the drug testing process.
    Some common delays in this DOT testing process may include:
    • Getting the specimen to the lab (sometimes not overnight),
    • MROs not receiving chains of custody and must take extra time to obtain it, and
    • Labs taking longer to verify results due to more confirmation tests happening
    In other words, more drivers will be found testing positive and either go through a SAP to eventually Return-to-Duty or leave the industry as a CDL driver.
    Historically, many of the drivers that tested positive and were let go tried to switch jobs and hide their positive drug test (or refusal to take a drug test) with their new employers. This “loophole” will now be closed with the FMCSA CDL drug and alcohol Clearinghouse going live January 6th, 2020.
    How The FMCSA CDL Clearinghouse Will Complicate Issues In 2020
    With the FMCSA CDL Drug and Alcohol Clearinghouse now live, the FMCSA Portal website (required to access for Clearinghouse registration) and the Clearinghouse website is crashing, and confusion is running rampant.
    The biggest issues the Clearinghouse will immediately cause will affect fleets that are hiring drivers in January. These fleets need to make sure they are registered to the Clearinghouse, which has been crashing for over a week.
    Many of these hiring fleets are likely to send in a potential new hire for a pre-employment drug test at a collection site. As required by the new rule, the driver needs to be “queried” to see if the database has any red flags on the driver. However, this driver is not registered in the Clearinghouse database to give consent that the company can run this query, causing a compliance issue.
    Before the driver can be tested for their pre-employment drug test, that driver (which is likely sitting at the drug testing site) will have to:
    • Register as a driver to the Clearinghouse
    • The employer will have to select the driver to request electronic consent of a query
    • The driver will need to give consent within the Clearinghouse, and then
    • The employer or their C/TPA can run a query on the driver.
    • If nothing is found in the database, the pre-employment drug test can continue.
    Issues to be aware of in this process:
    • If the employer sends a consent request to the driver… but the driver has not registered to the Clearinghouse to authorize consent, the FMCSA will mail a letter to the driver based on their license address about the consent request, which could take 2-3 weeks to get to the driver.
    • If the employer tells the drug testing site that the consent was received by the driver (but this never actually happened), the drug test site will note the consent and perform the drug test. Later, if that company is audited, the employer can be held at fault if the violation of no consent was caught.
    As you can tell, this will delay the pre-employment testing process and cause many headaches, especially for drug testing sites that are not up-to-date on FMCSA testing guideline changes or Clearinghouse rules.
    On the DOT auditor side, after any grace-period of getting everyone registered to the Clearinghouse (which the FMCSA has stated will NOT happen), auditors can look to see when a pre-employment drug test was completed and when the pre-employment Clearinghouse query was conducted. If the drug test date was BEFORE the query date, this would be out of compliance and could possibly receive a violation.
    Furthermore, auditors can easily see if annual queries in the Clearinghouse on all drivers were conducted or not. If not, the company is in violation and could face fines.
    Fleets that are hiring in January need to register to the Clearinghouse and make sure the potential new-hire driver also registers to the Clearinghouse. With the Clearinghouse website and FMCSA Portal website crashing, there may be a delay in this registration and pre-employment hiring process. If registration issues persist, try registering after normal working hours when the website has less people trying to register.
    x1Heavy Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    While we are at it just bolt drug testing kits to the steering column so that once daily you have to test in it. //snarky
    Badmon, Dave_in_AZ and clausland Thank this.
  4. Eddiec
    Eddiec Road Train Member
    2,323
    3,569
    Feb 2, 2015
    Just wait until hair follicle testing is mandatory for pre - employment screening
  5. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    It was 25%? I get hit so often the testing site knows my name
    mhyn and Dave_in_AZ Thank this.
  6. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    I was at my previous position 10 years. Never took a random after my pre-employment screen.
    Only 60 drivers.
    I've been at this position 10 years.
    I've not been called since my pre-employment screen.
    Close to probably 400 drivers (if not more).
    We have drivers that DO get called. I haven't been, though.
    I'd pass. I don't do anything.
    I've always wondered why.
    Dave_in_AZ Thanks this.
  7. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I might have been called two times in 10 years. IF that. And thats across thousands of drivers.
  8. Dumdriver
    Dumdriver Road Train Member
    1,525
    2,138
    Jul 8, 2014
    East Coast
    My company does three times the required testing. Every month. I’ve been tested eleven months straight in the past. I’ve gone months without being tested to. It’s overkill
  9. MidwestGator
    44
    79
    Jan 9, 2020
    Sounds like they don't understand the requirements. 50% of average driver size spread out over the year.
  10. z32sean
    z32sean Light Load Member
    110
    179
    Aug 9, 2016
    Middle Tennessee
    This is an inadvertent assault on smaller carriers. Drug testing costs will now double despite the miniscule increase in positive results. In an industry where time is money and there ain't much of either this hurts.
    Driving under the influence is never ok but of course positives are going to increase with the availability and lowered moral stigmas. The FMSCA, DOT and state highway patrols should all use their influence to get more reliable recent usage tests to market, that would really make a difference.
    Just passing by Thanks this.
  11. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Back when we first had to take drug test. I got hit every week for 3 weeks in a row. Then went a month then hit 2 times in one month. Found out I was the only driver that could pass the test. So find a new job.
    Hard to make $$ when your in the Dr's office peeing in front of the nurse all the time. And back then, we had to pee while they were in there. No bathroom, so lets say there sink smelled after I got done. Told the nurse ( Went to school with her) They had better get a bigger bottle. This one is way to small! She told me was not her problem. So Sink was it.:D
