5309. 5 pick ups. Help.
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Jeron379, Sep 16, 2017.
  1. Jeron379
    Jeron379 Bobtail Member
    22
    6
    Aug 15, 2009
    Moncton New Brunswick
    Rookie here. What am I doing wrong. I cannot get this top deck under 14-6-15'. Need 13-6.
  3. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    I don't see it happening
    Orangees and BigBob410 Thank this.
  4. Jeron379
    22
    6
    Aug 15, 2009
    Also tried different pick up today using drop pockets. Still no go.
  5. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Different trailer but I believe we were 13'6" or could have gotten to 13'6" on this load? 20140927_143450.jpg
  6. Jeron379
    22
    6
    Aug 15, 2009
    I actually had your photo saved in my phone. But I couldn't get anywhere close to 13-6
    KANSAS TRANSIT Thanks this.
  7. crb
    1,676
    1,374
    Dec 1, 2009
    USA
    Drop pockets where rear wheels are on middle unit would help.
  8. Kawinige01
    Kawinige01 Heavy Load Member
    864
    1,151
    May 30, 2016
    South Fla
    try driving the last one on the bottom one on. can you move the 1st one further towards the front?
  9. Kawinige01
    864
    1,151
    May 30, 2016
    South Fla
    lift up the back of the deck on the 5th wheel and pull the truck in the belly as far forward as you can and try driving the one on over the tandems. then put the one on the tail up top as far back as you can
  10. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    That's basically a 7512 quickloader with a front deck and high 5th wheel. I agree with what he said above. Just flip the truck on the back bottom around with the front tires on the long drop deck, drop the back tires which will be on the back bottom deck until it's sitting nearly on the frame. The front posts on the long top deck need to be lowered as far as possible. Leave the middle posts high and the back top posts low making an inverted V.
    Jeron379 Thanks this.
  11. Kawinige01
    864
    1,151
    May 30, 2016
    South Fla
